Light smoke or steam coming out of engine!
Old Apr 22, 2004 | 09:50 AM
PolySquared's Avatar
Default Light smoke or steam coming out of engine!
When idling, light colored smoke or steam is coming out of my small filter from the engine. If I replace that little filter with the stock line, the same smoke releases from the bov. My car run's perfectly fine, but it has a slight idle like a wrx. HELP!
I'm running Drag kit, hondata, walbro255 fuel pump, aem fpr new plugs, new wires, new cap/rotor.
Old Apr 22, 2004 | 09:56 AM
SiRkid's Avatar
Default Re: Light smoke or steam coming out of engine! (PolySquared)
idle like a wrx??? sounds like it? that means misfire(a cylinder isnt firing)
Old Apr 22, 2004 | 10:15 AM
HybridKOOP's Avatar
Default Re: Light smoke or steam coming out of engine! (SiRkid)
No, headgasket or bottom end probably has a problem. Could be a cracked ringland on a piston, or the headgasket could be shot... do a leakdown
Old Apr 22, 2004 | 10:48 AM
hulkhb's Avatar
Default Re: Light smoke or steam coming out of engine! (HybridKOOP)
That sucks, i cant wait for that to happen to mine
hope its somthing small.
Old Apr 22, 2004 | 11:31 AM
Hoosier Daddy's Avatar
Do a compression test. That should tell you whether it's anything major or not.
Old Apr 22, 2004 | 11:36 AM
brkrnu's Avatar
Default Re: Light smoke or steam coming out of engine! (hulkhb)
I had the same problem and it turns out that the piston ring lands were cracked and broken on three of my pistons. I got the pistons out of the cylinders and **** started falling apart. This was with a tuned EMS and no detonation ever heard. The stock Honda pistons do not like boost at all.
My cost to replace....
CP pistons & rings $500
Eagle rods $340
New Honda headgasket $75
ARP headstuds $107
New oil, coolant, etc. $40
This is not even counting new bearings and the labor to get it done. I was very lucky that I did not drive the car that long once I noticed this otherwise I would have scarred my cylinder walls and at that point I would have needed to take the block out of the car and send it to a machine shop. That would be another couple hundred bucks in labor for taking it out and the machine shop cost.
Not to scare you or anything but do a search on this subject and you will see some scary **** that happens to these stock pistons.
Who said that turbocharging a Honda was cheap ????
Old Apr 22, 2004 | 11:48 AM
m R g S r's Avatar
Default Re: Light smoke or steam coming out of engine! (brkrnu)
All of my ringlands were cracked, but I didn't even know about it. I found that out after I cracked a sleeve and pulled the motor apart.
Old Apr 22, 2004 | 11:55 AM
seen4ever's Avatar
Default Re: Light smoke or steam coming out of engine! (m R g S r)
ringland or pistons is screwed. I've seen this happen on a couple cars around here, basicly stock pistons hate the boost.
Old Apr 22, 2004 | 12:05 PM
fjt's Avatar
fjt
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brkrnu &raquo;</TD></TR><TR><TD CLASS="quote">I had the same problem and it turns out that the piston ring lands were cracked and broken on three of my pistons. I got the pistons out of the cylinders and **** started falling apart. </TD></TR></TABLE>
LOL it happened exactly like that to me...And i also had a Broken HG and my breather smoked a lot.
Old Apr 22, 2004 | 12:10 PM
RTW DC2R's Avatar
what exactly is a "ringland"
Old Apr 22, 2004 | 12:16 PM
Default Re: (RTW DC2)
Well, it's not coming out of the bov. It is coming straight out of the breather and I can feel motor oil is slightly around it. My idle got poor too...
Somebody told me that my motor is getting really worked. Going to blow? AHHH
brkrnu's Avatar
It's the piece of metal that likes to break on your pistons.
There are two rings on the piston separated by a piece of metal. That metal between the two rings breaks under stress.
Do a compression test and get it fixed asap to minimize the damage.
Old Apr 22, 2004 | 12:18 PM
VisualAutoMotoring's Avatar
Default Re: (brkrnu)
your are getting blow by....compression check or leakdown...
check your oil level
brkrnu's Avatar
Default Re: (PolySquared)
Any smoke coming out of your breather filter is a bad thing. I bet that if you spin the filter around you have oil that has accumulated on the bottom and it is possible that you have some sludge down near your injectors.
You will not see smoke coming out of the bov because you do not build boost at idle.
Old Apr 22, 2004 | 12:21 PM
Yes. I'm losing a great amount of oil.
Thanks guys, I'm getting a lots of quick help! I really appreciate it
Old Apr 22, 2004 | 01:35 PM
vtec.dc2's Avatar
any smoke is not good.. so don't beat the **** out of it, check compression first. could be headgakset, but could also be piston rings resulting in blow-by.
i don't run fitler on mine, especially if you happend to be collecting oil inside of fitler - that way it won't breathe out.. at this time i dont think it will matter
Old Apr 22, 2004 | 03:44 PM
illi Adik's Avatar
Default Re: (vtec.dc2)
As said above, run the tests on it...my guess is a cracked ringland(s).
Old Apr 27, 2004 | 11:27 PM
Default Re: (Jackson4Door)
Well, the mechanic says I need a new block and new pistons. Could it be possible my block was cracked? He also mentioned how my pistons broke inside.
Old Apr 27, 2004 | 11:29 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolySquared &raquo;</TD></TR><TR><TD CLASS="quote">Well, the mechanic says I need a new block and new pistons. Could it be possible my block was cracked? He also mentioned how my pistons broke inside.</TD></TR></TABLE>
the mechanic has no idea if the block is toast by not taking the head off and pistons out
mike
Old Apr 27, 2004 | 11:36 PM
iam7head's Avatar
Default Re: (MikeMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">
mike</TD></TR></TABLE>
I am putting my bet on piston also but he can't tell the block is toasted or not without taking off the head, unless you got a big hole on the block or something
Actually, he did mention how he took the whole head off. I'll be stopping by the shop the next thing in the morning. He quoted me 1500 for new block and pistons installed. Good deal?
He is supposely a good buddy of mine.
Old Apr 27, 2004 | 11:43 PM
MikeMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PolySquared &raquo;</TD></TR><TR><TD CLASS="quote">Actually, he did mention how he took the whole head off. I'll be stopping by the shop the next thing in the morning. He quoted me 1500 for new block and pistons installed. Good deal?
He is supposely a good buddy of mine.</TD></TR></TABLE>
hmm, $1500 for a new block and pistons installed isnt bad at all if it includes the labor AND pistons + block.
mike
Old Apr 28, 2004 | 12:54 AM
Trac226's Avatar
Had the infamous white smoke coming out of the breather filter thing as well....
I ended up buying:
a used block for $850
head check, cleaning, valve stem replacement $130
Overhaul Kit + headgasket $100
So the price aint bad at all for $1500 esp for a "new" block and pistons. You could always spend a little extra, sleeve, forged internals, and do the work yourself to save money
Old Apr 28, 2004 | 01:36 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (Trac226)
its the ringlands , im going through the same **** .
https://honda-tech.com/zerothread?id=844289
its your ringlands . if your cooland and oil havnent mixed its not your headgasket .
i was pretty pissed it happened to me considering i had tuned it 6 days before . oh well the buildup is beginning.
good luck with your setup . and that mechanic who said you need a new block , needs another profession . at the worst you need your cylinders machined . prolly just need a hone and new pistons
Old Apr 28, 2004 | 05:23 AM
Alstare's Avatar
Default Re: (Hella_JDM)
I had the WRX sound aswell...lol
It was was blown ringlands...
Sorry about your luck man.
Time to build it up!!!
