How can I get my engine to pull more vacuum?
Hi, I used to be turbo'd now I reverted back to stock on my 2000 civic si. I have the stock ECU in there, but since I have lower compression pistons (9.4:1) it doesnt pull enough vacuum at idle so the ECU is confused and dumps too much fuel, causing my code 45 to pop up. How can I get it to pull a little more vacuum so it can run right. It pulls about 16 inches right now, so I just need about 2 more inches. Thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos »</TD></TR><TR><TD CLASS="quote">
You could try to grow some carbon build up on your pistons... </TD></TR></TABLE>
LOL
LOL
the compression of your pistons have anything to do with it. my car pulls 20-22in of vacuum and its 9:1. your car is idling kinda rough because of too much fuel or lack of fuel and it will cause shitty vacuum. hence the code 45 (system to lean or rich).
i dont know if u have anything to adjust your fuel but it sounds like it needs some adjusting
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 »</TD></TR><TR><TD CLASS="quote">did u put yoru stock injectors back in </TD></TR></TABLE>
I was going to ask that too
i have stock ecu, stock injectors, stock fuel pump. car is running rich. I dont know what else could cause that. i replaced o2 sensors, had the electrical system check out by a mechanic, everything checked out fine.
fredtoast
Dec 21, 2005 12:54 PM
hitvtecgetloud09
Apr 22, 2004 02:10 AM
.... Why did you go back to stock?
