new to boosting and trying to figure out setup
Old May 5, 2004 | 09:21 AM
92_red_teg's Avatar
Default new to boosting and trying to figure out setup
Ok, right now I have a b18b with P+P head, ss valves, dual springs, reatiners and stock cams, 62 mm throttle body, skunks 2 intake manifold, the block is just stock with CTR pistons and shot peened rods
my question is what cams should I get and can I run high boost like 14-15 PSI on my current setup, with CTR pistons, or would I blow my engine because the compression is too high, also, what turbo should I use for my setup, I want to achieve 300 HP, and if anyone knows, what would be a good clutch to run, sorry for all the questions, I want to do it right the first time around. I teied search but could not find any real info on complete setups. thanks in advance
Old May 5, 2004 | 12:40 PM
92_red_teg's Avatar
Default Re: new to boosting and trying to figure out setup (92_red_teg)
bump, need help
Old May 5, 2004 | 01:54 PM
LostCRX's Avatar
people are going to tell you to search.
EG6-baybee
Dec 10, 2007 10:02 PM
dajman94
Jun 25, 2005 05:29 PM
Chaos69
Mar 9, 2004 08:16 PM
Brian*
Jan 30, 2002 07:03 PM
