How can I get my engine to pull more vacuum?
Old May 4, 2004 | 08:15 AM
Hoodwinked's Avatar
Default How can I get my engine to pull more vacuum?
Hi, I used to be turbo'd now I reverted back to stock on my 2000 civic si. I have the stock ECU in there, but since I have lower compression pistons (9.4:1) it doesnt pull enough vacuum at idle so the ECU is confused and dumps too much fuel, causing my code 45 to pop up. How can I get it to pull a little more vacuum so it can run right. It pulls about 16 inches right now, so I just need about 2 more inches. Thanks!
Old May 4, 2004 | 08:16 AM
11psiTurboSI's Avatar
Default Re: How can I get my engine to pull more vacuum? (Hoodwinked)
Put the stock pistons back in .... Why did you go back to stock?
Old May 4, 2004 | 08:25 AM
mos's Avatar
mos
Default Re: How can I get my engine to pull more vacuum? (9psiTurboSI)
Can't a cheap used AFC or an SMC do exactly what you want?
You could try to grow some carbon build up on your pistons...
Old May 4, 2004 | 08:32 AM
Default Re: How can I get my engine to pull more vacuum? (mos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">
You could try to grow some carbon build up on your pistons... </TD></TR></TABLE>
LOL
Old May 4, 2004 | 08:36 AM
99B16Si's Avatar
the compression of your pistons have anything to do with it. my car pulls 20-22in of vacuum and its 9:1. your car is idling kinda rough because of too much fuel or lack of fuel and it will cause shitty vacuum. hence the code 45 (system to lean or rich).
i dont know if u have anything to adjust your fuel but it sounds like it needs some adjusting
Old May 4, 2004 | 08:59 AM
RAWB's Avatar
Default Re: (99B16Si)
Have you checked for a vacuum leak?
Old May 4, 2004 | 09:55 AM
Turbo E's Avatar
retune.
Old May 4, 2004 | 09:58 AM
spark plugs.
Guest
Posts: n/a
Default Re: (Turbo E 604)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo E 604 &raquo;</TD></TR><TR><TD CLASS="quote">retune.</TD></TR></TABLE>
retune what? he has a stock ecu, doesn't he?
Old May 4, 2004 | 10:15 AM
99B16Si's Avatar
do u have an after market pump in there? that could cause your fuel pressure to rise quite a bit making your car run too rich
Old May 4, 2004 | 10:18 AM
u2civic1's Avatar
did u put yoru stock injectors back in
Old May 4, 2004 | 11:18 AM
FredoSP's Avatar
Default Re: How can I get my engine to pull more vacuum? (u2civic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by u2civic1 &raquo;</TD></TR><TR><TD CLASS="quote">did u put yoru stock injectors back in </TD></TR></TABLE>
I was going to ask that too
Old May 4, 2004 | 12:01 PM
JDogg's Avatar
Default Re: How can I get my engine to pull more vacuum? (FredoSP)
you have something else wrong...... i have tuned cars with as low as 7.8:1 and they pulled vacuum just fine.
Old May 4, 2004 | 08:35 PM
Hoodwinked's Avatar
Default Re: How can I get my engine to pull more vacuum? (JDogg)
i have stock ecu, stock injectors, stock fuel pump. car is running rich. I dont know what else could cause that. i replaced o2 sensors, had the electrical system check out by a mechanic, everything checked out fine.
Old May 4, 2004 | 09:50 PM
Hoodwinked's Avatar
bump
Old May 5, 2004 | 08:03 AM
Hoodwinked's Avatar
up
Old May 5, 2004 | 01:32 PM
legendboy's Avatar
Could be cam timing. Change your belt lately??
fredtoast
Dec 21, 2005 12:54 PM
DMF
37
Dec 28, 2004 10:44 PM
GWInquisitor14
Jun 16, 2004 06:45 PM
hitvtecgetloud09
Apr 22, 2004 02:10 AM
