How many tranny bolts on a b16a2
Old May 3, 2004 | 09:45 PM
rocco's Avatar
Default How many tranny bolts on a b16a2
How many tranny bolts on a sir2,i think i have got them all but the tranny wont budge
Thanks
Old May 3, 2004 | 09:53 PM
Ski11z's Avatar
Default Re: How many tranny bolts on a b16a2 (rocco)
You need to take the cap off located above the main shaft (top of trans). The cap looks like a round circle about the size of a condom with a 1/2 inch square in the center of the circle. After you take the cap off there is a lock ring which you need to expand off the shaft then tap the case off with a rubber mallet.
Old May 3, 2004 | 09:59 PM
rocco's Avatar
Default Re: How many tranny bolts on a b16a2 (Ski11z)
does anyone have a pic of this
Old May 3, 2004 | 10:58 PM
rocco's Avatar
bump
Old May 3, 2004 | 10:59 PM
The Internet Tough Guy's Avatar
are you trying to open the tranny up or remove it from the car?
Old May 3, 2004 | 11:08 PM
=GAME='s Avatar
did you remove the starter?
Old May 3, 2004 | 11:14 PM
rocco's Avatar
Default Re: How many tranny bolts on a b16a2 (=GAMEOVA=)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by =GAMEOVA= &raquo;</TD></TR><TR><TD CLASS="quote">did you remove the starter?</TD></TR></TABLE>yup,and the bolt under the clutch master cylinder,the two bolts on each side of the serial number,i think 2 bolts in the back and the tranny brackets,what else am i missing
Old May 3, 2004 | 11:17 PM
=GAME='s Avatar
https://honda-tech.com/zerothread?id=596873
should be similar.
Old May 3, 2004 | 11:47 PM
did you remove the clutch dust cover? i've forgotten that before.
Old May 4, 2004 | 01:27 AM
Ski11z's Avatar
Default Re: How many tranny bolts on a b16a2 (jwn7)
You still did not mention if you had the trans out and were trying to take the casing apart to look inside the trans. Anyways, if you have the transmission out and are trying to take the cover off then you will need to take ALL the bolts off the trans, yes even the side, I do believe their is 3 bolts on the side 2 which push a spring that have a little ball that touches the forks, you also need to remove the screw that is holding the reverse pin down. You also have to remove that round cap on the top of the trans and get the locking retainer off that is connected to a bearing with a locking clip.
Look at this pick the bearing I am talking about is the one in the middle of the pic which looks like their is 2 bearings one on top of the other there is a groove in the top bearing where the clip is locked around That must be taken off the bearing, but it doesen't come out of the case.
Old May 4, 2004 | 08:09 AM
rocco's Avatar
no dude,im trying to take the tranny out
Old May 4, 2004 | 01:42 PM
ironcheftony's Avatar
remove both axles , unbolt the rear mount, 4 bolts total, 3 from driver side, 1 from passenger side, , then 2 under the distributor, should be 2 or 3 on front side of the trannny, make sure to remove the flywheel cover, 10mm 12mm bolts, should be lik 3, then remove the 2 brackets on the bottom of the motor that hold the tranny and motor together, then the torque mount on the front, then the tranny mount, hope that helps
Old May 4, 2004 | 01:54 PM
rocco's Avatar
Default Re: (ironcheftony)
remove both axles? this is new to me
Old May 4, 2004 | 02:19 PM
Default Re: (rocco)
hahah yeah you definately need to do that. go in the faq thread, the very first link is how to remove them.
how to remove your tranny: https://honda-tech.com/zerothread?id=596873
Old May 4, 2004 | 03:36 PM
Blacklightning's Avatar
Default Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 &raquo;</TD></TR><TR><TD CLASS="quote">how to remove your tranny: https://honda-tech.com/zerothread?id=596873</TD></TR></TABLE>Hey Rocco with all this info, your car should be up and running by Sunday . Good luck I look forward to our cruise.
Old May 4, 2004 | 03:39 PM
oooo forgot!, both axles plus the intermediate shaft! which is held on by 3 14mm bolts
Old May 8, 2004 | 11:55 AM
just take you r time, by sundat night you should be all done
Pishpeng
10
Feb 15, 2007 02:44 PM
Ej1_coupe
May 17, 2005 08:37 PM
Ben_si
10
May 3, 2005 08:33 AM
Unjockable
20
Nov 10, 2003 02:36 PM
rig9896
May 11, 2003 05:29 AM
