wider wheels
Disadvantages: heavier, rubbing depending on rim offset and how much lowered.
Just get rims with the right offset for your wide tires. What size do you plan to get?
I think 225 is pretty good. With a 1-1.25" gap, you probably only have to worry about rubbing on turns with super wide tires. Wide tires + tucking = probably not good. I don't think an inch will be a big problem. So, what size tire will you'll be running?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RsxVengeance »</TD></TR><TR><TD CLASS="quote">you can run a 8.5 inch wide rims with 40mm offset with no rubbing problems. If traction is what you want then you can fit some 235 tires on those rims above.</TD></TR></TABLE>
holy ****!! 8.5"????
235's??
stock fender fitment? if so rsx's rock! my roommate's got 8.5's on his 400WHP wrx and they are crazy. I cant imagine them on an RSX! wow
I think I can only fit 7.0's on my Si.
235's??stock fender fitment? if so rsx's rock! my roommate's got 8.5's on his 400WHP wrx and they are crazy. I cant imagine them on an RSX! wow
yeah 8.5 is no problem. I even heard some dude's running 9 inch wide rims. The trick is all in the offset, my volk ce28n is 8.5 with 40mm offset which is perfact for the rsx,235 on my rims doesn't rub.
stmotorsports
Aug 3, 2004 06:18 AM
JD_B18CDX
Jan 16, 2002 04:47 PM
