will 15x7.5" or 15x8" wheels fit on an eg?
Old 08-01-2004, 10:44 AM
stmotorsports's Avatar
Default will 15x7.5" or 15x8" wheels fit on an eg?
uh... yeah what he said....
looking to go 225/45/15 tires for auto-x next year but i don't think 15x7" rims will be quite wide enuff for r-comps...
these would be my track only wheels/tires so i don't really think it would matter too much if they rub only at full lock- how often do you go full lock on course? unless you spin it and have to back up
my car is lowered pretty much right to the tires so i would need to stay right around a 40mm offset or greater
anyone have any thoughts?
stmotorsports is offline
Old 08-02-2004, 09:09 PM
Default Re: will 15x7.5" or 15x8" wheels fit on an eg? (stmotorsports)
pttthhhhttt
Old 08-02-2004, 09:12 PM
Spade's Avatar
225 is too large IMO. 205 is more than enough and has a large selection including the infamous Azenis.
Spade is offline
Old 08-02-2004, 09:16 PM
Marauder's Avatar
Default Re: will 15x7.5" or 15x8" wheels fit on an eg? (Spade)
I have 17x7.5 on my civic, only slight rub at full lock, with 205/40r17 tires, with a 45 offset.
8" wide is too much, but I think you'd be able to get away with a 215 wide tire. For a 225, you'd have to raise your car and for a 8" wide rim you'd need a huge offset and maybe even a spacer.
Marauder is offline
Old 08-02-2004, 10:10 PM
Default Re: will 15x7.5" or 15x8" wheels fit on an eg? (Marauder)
unfortunately unless some of the tire manufacturers are planning on coming out with some new sizes for next year, tire size selection of auto-x race compounds is fairly limited, pretty much either 205/50 or 225/45 would be the only width/profile I could really consider running. I've never seen a 215...
I'm running 205/55/14s on 14"x6" rims on the car now as I was competing in stock class up until I lowered it and did a bunch of other misc. stuff recently, but now that I don't have to worry about the stock wheel size requirements anymore I figured I would see if I could squeeze something a little wider on there...
I dunno... ??
Old 08-03-2004, 04:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">I have 17x7.5 on my civic, only slight rub at full lock, with 205/40r17 tires, with a 45 offset.
8" wide is too much, but I think you'd be able to get away with a 215 wide tire. For a 225, you'd have to raise your car and for a 8" wide rim you'd need a huge offset and maybe even a spacer.</TD></TR></TABLE>
i have the same size rims 17x7.5 (5zigen copse) in my EJ6 95 coupe and i dont rub at all. no spacers. i use the nitto tires if that helps. very good grip too!
JinDIESEL is offline
Old 08-03-2004, 06:18 AM
jg
...do search for 15x8. This has been covered.
https://honda-tech.com/zerothread?id=525452
jg is offline
cdaiscool
09-07-2016 12:58 AM
moaterboaink1ng
Suspension & Brakes
10-29-2012 11:42 AM
silver05civicLXse
09-11-2011 01:23 PM
2000EJ8
11-12-2010 08:09 PM
kent, clark
12-15-2001 01:32 PM
Quick Reply: will 15x7.5" or 15x8" wheels fit on an eg?
  • Ask a Question
Question Title:
Description:
