Once and for all can this be solved? Oil pan D series
because the oil pumps are different
the pans have the same patterns, but the bolts where it goes to the oil pump vaires from D15 to D16 (my onw experience)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cruiser G »</TD></TR><TR><TD CLASS="quote">I know a z6 pan will not fit a '00 y8 if that helps any
fully aware of that because of the y8 has the aluminum pan!!!
</TD></TR></TABLE>fully aware of that because of the y8 has the aluminum pan!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC »</TD></TR><TR><TD CLASS="quote">because the oil pumps are different
the pans have the same patterns, but the bolts where it goes to the oil pump vaires from D15 to D16 (my onw experience)</TD></TR></TABLE>
well this will be d16z6 mated to a d16y7 , i will have a definite answer tommorow, i'll just go pick up my spare block and test it with my z6 pan!!!! i need to get a return welded in and all i have is a z6 pan for my y7 thats in my car now!!!
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I have a Z6 pan on my 97 Y8. I had to dremel out two of the mounting holes a little bit near the crank pulley to make it fit flush. BUT IT DOES NOT JUST BOLT ON.
BTW, Y7 and Y8 blocks are basically identical, so it should work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">I have a Z6 pan on my 97 Y8. I had to dremel out two of the mounting holes a little bit near the crank pulley to make it fit flush. BUT IT DOES NOT JUST BOLT ON.
does it leak?
</TD></TR></TABLE>does it leak?
Seems answered but I also know a d15b7 oil pan will not fit on to a d16y7.. I also thought about swapping the oil pickup but the sizes where they mount are different..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">
does it leak?</TD></TR></TABLE>
Now that I think about it, a little bit.
well i welded my bung into i so i guess i'll have to goop it up around that opening!!!!! i hate leaks and will seek and destroy!!!!!!!
</TD></TR></TABLE>well i welded my bung into i so i guess i'll have to goop it up around that opening!!!!! i hate leaks and will seek and destroy!!!!!!!
well i welded my bung into i so i guess i'll have to goop it up around that opening!!!!! i hate leaks and will seek and destroy!!!!!!!</TD></TR></TABLE>
I love your avatar.. I just ordered a poster with the same thing on it..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by warwagon »</TD></TR><TR><TD CLASS="quote">what the nip shot.... somebody is making money off that..... imagine that</TD></TR></TABLE>
Is that an olson twin?
warwagon
11
Feb 5, 2004 06:33 PM
JCracer723
Jun 6, 2003 10:37 AM
