help on OBD0 TO OBD1!!!!
Old May 3, 2004 | 10:19 AM
90CRXHONDA's Avatar
Default help on OBD0 TO OBD1!!!!
ok, just need to get this verified, i am puttin a 92-93 sir ver2 into my 1990 crx, is it true that all i have to do to make it work with a obd0 is to, use a obd0 intake manifold/throttlebody, distributor, and ecu, along w/the obd0 wiring for a b16? someone told me thats it, i had a 1st gen b16 in it, but engine blew, now have this new engine coming, so i already have the obd0 manifold, dist, ecu,wiring, would this work?
Old May 3, 2004 | 10:47 AM
tgreaves's Avatar
Default Re: help on OBD0 TO OBD1!!!! (90CRXHONDA)
Should work.. The motor doesnt know what obd is running it and the obd0 ecu and wiring doesnt know what motor its powering.. I was running a 93' d15b7 motor on an obd0 pm6 ecu for a while and it worked great..
Old May 3, 2004 | 10:49 AM
tgreaves's Avatar
Default Re: help on OBD0 TO OBD1!!!! (tgreaves)
Opps.. forgot to add.. I was also using an obd1 intake manifold, throttlebody, and map sensor.. I dont know anything about the sir v2 motor and what you can use on it.. I just know what I used on my d15 motor..
prelude2121
Engine Management and Tuning
Oct 29, 2010 04:23 PM
crazyef8
10
Apr 20, 2009 09:44 PM
My_EFsedan
Oct 25, 2008 11:21 AM
meseetree
Mar 24, 2006 02:20 PM
dpw41285
Mar 30, 2004 07:10 AM
