distributor swap (already searched)
Old May 3, 2004 | 08:58 AM
servion's Avatar
Default distributor swap (already searched)
I'd like to find out what all distributors I can directly bolt onto my b18c. In the saearch, I discovered that I can run b16a or b18c dsitributors... but that about d-series ones.... will the fit?
My distributor needs replacing, and I want to know what all distributors will bolt on without modification. Will there by a problem with different number of teeth between any distributors?
Old May 3, 2004 | 10:12 AM
kur0ryu's Avatar
Default Re: distributor swap (servion)
rarely does anything swap between b series and d series. You won't be able to use a d series distributor. If you're engine is obd-1, you probably need a TD-44U dizzy.
Old May 3, 2004 | 10:29 AM
servion's Avatar
Default Re: distributor swap (kur0ryu)
What about the sensors inside?
I'm getting a code 9 (cylinder position sensor). Could I replace the sensor in my GSR distributor with one from a d16?
Old May 3, 2004 | 12:37 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">What about the sensors inside?
Could I replace the sensor in my GSR distributor with one from a d16?</TD></TR></TABLE>
YES, you can do this.
As long as the B & D series distributors are of the same OBD type; you an swap the ignitor & coil between B & D series distributors respective to OBD type.
Old May 3, 2004 | 02:03 PM
servion's Avatar
Default Re: distributor swap (Katman)
Ahh... interesting... I though all OBDI and OBDII distributors were internall interchangeable.
What about the CYP sensor... can I yank one out of, say, a y8 distributor and then put it into my OBDII gsr distributor? What about a z6 CYP?
Old May 3, 2004 | 04:37 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">Ahh... interesting... I though all OBDI and OBDII distributors were internall interchangeable.
What about the CYP sensor... can I yank one out of, say, a y8 distributor and then put it into my OBDII gsr distributor? What about a z6 CYP?</TD></TR></TABLE>
doesn't hurt to try it and find out
Old May 4, 2004 | 08:06 AM
servion's Avatar
For those interested:
I pulled out a CYP sensor from an OBDII d-series distributor and put int into my GSR distributor. This fixed the problem completely. The only change I had to make was to the pins on the CYP sensor that go into the harness plug. The pins were shorter on the d-series CYP sensor, so I cut them off and soldered on the ones from the GSR CYP.... problem solved !!
Old May 4, 2004 | 10:16 AM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">For those interested:
I pulled out a CYP sensor from an OBDII d-series distributor and put int into my GSR distributor. This fixed the problem completely. The only change I had to make was to the pins on the CYP sensor that go into the harness plug. The pins were shorter on the d-series CYP sensor, so I cut them off and soldered on the ones from the GSR CYP.... problem solved !! </TD></TR></TABLE>
ya see!
it didn't hurt to try it out, now did it!
Old May 4, 2004 | 02:01 PM
servion's Avatar
Of course not I was just hoping to save the trouble if someone else already knew... but now I (any anyone else reading this thread) knows
90civicbns
Aug 5, 2013 09:53 AM
raidacaipo
May 24, 2009 09:28 AM
JeffBro
Mar 23, 2008 11:52 AM
chris_c
Dec 3, 2004 06:44 AM
rc1320
Aug 24, 2002 07:03 PM
