Check engine light when going into VTEC
Old May 2, 2004 | 02:13 PM
Jamez's Avatar
Default Check engine light when going into VTEC
(D16Z6 SOHC VTEC)
I recently removed the head off my engine for a mild rebuild, porting and head milling of 0.030". Now when I redline the car I get a check engine light. Otherwise everything seems fine, runs smooth and I checked all connections I had to unplug/replug numerous times. Also, VTEC seems to engage as the engine pulls strong to redline.
I'm just at a lost for what could be causing this. Could the higher compression ratio be messing with the air/fuel ratio? Anyone ever experience something like this?
Old May 2, 2004 | 02:24 PM
kur0ryu's Avatar
Default Re: Check engine light when going into VTEC (Jamez)
what code is your ecu throwing?
Old May 2, 2004 | 02:33 PM
Jamez's Avatar
Default Re: Check engine light when going into VTEC (kur0ryu)
If I knew I probably wouldn't be asking for help
I don't have the equipement to check the codes, I'm hoping someone who experienced the same thing or heard of it happening could help me out before I bring the car into the shop at school.
813tampa
Apr 10, 2008 02:59 AM
xjustinx
Apr 14, 2006 09:12 PM
springfieldcivic
15
Jun 24, 2005 02:26 PM
grlstockb18c1
Nov 3, 2004 07:07 PM
inzaneN1
Dec 3, 2003 01:34 AM
