Vtec not working and won't rev past 5k
Old May 1, 2004 | 09:35 PM
EG1.8cT68's Avatar
Default Vtec not working and won't rev past 5k
I just recently put a B16 head on my friends 00 GS-R-He bent 6 valves but the car ran fine, Vtec worked and no oil being burnt for 2-3 months. Any way after doing the head swap we test drove the car everything worked fine.Vtec engaged and redline was normal. Now 2 days later car won't rev past 5k hits rev limit and at 4500k won't engage Vtec. I already checked the oil level and it was right at the second dot on the stick. But when I pulled the stick out there was a little smoke exiting the tube.
Any and All imput would be appreciated.
Old May 1, 2004 | 09:59 PM
Sliced Beard's Avatar
Default Re: Vtec not working and won't rev past 5k (EG1.8cT68)
are there any CEL's?
Old May 1, 2004 | 11:46 PM
gumbii's Avatar
sounds like the ecu is tripping... or the timing... check for some cells... and the timing...
Old May 3, 2004 | 10:58 AM
tgreaves's Avatar
Check the filter on the vtec noid..
Old May 3, 2004 | 11:10 AM
strepto's Avatar
Default Re: Vtec not working and won't rev past 5k (tgreaves)
Damn.. I feel ya on that one.. This happened to me: https://honda-tech.com/zerothread?id=812652
Old May 3, 2004 | 12:34 PM
EG1.8cT68's Avatar
The ecu is throwing code 22 - Vtec malfunction. When I switched the heads I did not replace the vtec filters or solenoids. I will try tonight and see what happens.
Old May 3, 2004 | 12:36 PM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG1.8cT68 &raquo;</TD></TR><TR><TD CLASS="quote">The ecu is throwing code 22 - Vtec malfunction. When I switched the heads I did not replace the vtec filters or solenoids. I will try tonight and see what happens.</TD></TR></TABLE>
Try replacing the filter.. If you need my expertise just let me know..
Old May 3, 2004 | 07:41 PM
EG1.8cT68's Avatar
Well Vtec pressure switch was bad-damn I have electronics but Vtec now works and the car pulls fairly hard.
Tgreaves I will give you a call for your expertise soon enough!
Thanx for everyones input Greatly appreciated.
avinad
Jun 19, 2007 05:25 AM
DIYMIKE
May 30, 2004 11:46 AM
f@sth@tch89
Feb 5, 2004 07:49 PM
sk8phaze
Jul 28, 2003 07:44 PM
jared703
Dec 13, 2001 09:46 AM
