Vtec not engaging..
Old Dec 11, 2001 | 11:38 AM
jared703's Avatar
Default Vtec not engaging..
My vtec is not engaging, I just had the timing belt redone a couple weeks back after some seals burst and all my oil emptied out . Now, about 2-3 weeks later my vtec stopped engaging. Oil level is perfect. Sounds like vtec wants to go but in the 5200 turnover point the intake just sounds like it's ripping really hard, not like normal vtec, and vtec doesn't occur. Any advice?
thanks.
Old Dec 11, 2001 | 11:46 AM
Greyout's Avatar
Default Re: Vtec not engaging.. (jared703)
when you dumped all your oil, did you do any damage to the motor?
Old Dec 11, 2001 | 11:58 AM
prelude1897's Avatar
So you're saying that whenever you hit VTEC, it doesn't pull or it just doesn't kick in at all??
Old Dec 11, 2001 | 12:37 PM
jared703's Avatar
Default Re: Vtec not engaging.. (JDM LUDE)
i'm guessing no, I had it towed right away and vtec was fine for a week or two after the timing belt change. I also use mobil 1.
Old Dec 11, 2001 | 01:20 PM
T817's Avatar
are you throwing any codes?
Old Dec 11, 2001 | 02:43 PM
jared703's Avatar
Default Re: Vtec not engaging.. (A_red_car)
nah, throwing no codes... forgot to mention that. Any idea's people?
Old Dec 11, 2001 | 11:51 PM
BlueShadow's Avatar
could it be a problem with the VTEC solenoid?
Old Dec 12, 2001 | 04:07 AM
urbanlegend21's Avatar
New User
Default Re: Vtec not engaging.. (BlueShadow)
I believe if it was the VTEC solenoid it would be throwing a code, but check it anyway. Also how many miles are on your car? Do you use Mobil 1 sythetic or just Mobil 1? Have you switched between the two?
Old Dec 12, 2001 | 04:28 AM
LudeBehavior's Avatar
New User
Default Re: Vtec not engaging.. (urbanlegend21)
the only time my vtec doesn't kick in, is when I first start it. I think it has to do with the correct oil pressure, not sure tho. When it warms up however it's fine.
Old Dec 12, 2001 | 05:19 AM
WICKED2's Avatar
New User
dat burst u'r talking about is its an oil burst if so da reason y u'r vtec not kicking in is b-cuz u'r losing some oil presure
Old Dec 12, 2001 | 05:39 AM
BlueShadow's Avatar
Default Re: Vtec not engaging.. (LudeBehavior)
thats normal behavior though, VTEC will not engage until the car is fully warmed up. it will also not engage properly if your oil pressure is very low.
Old Dec 12, 2001 | 08:12 AM
jared703's Avatar
my car is fully warmed up.. as far as I know every oil change I've done is been with mobil 1 synthetic. If there was a mix up for whatever reason would that cause vtec to not activate? My cel came on a few weeks back but was only on for a few hours a couple days, the light hasn't been on since. Vtec was working fine then though. As of this morning vtec still is not engaging, and there are no bursts of vtec (that would be the pressure being to low and vtec would be choppy..). So a cel code would be thrown for the vtec selonoid? Is the vtec selonoid visable, where is it located?
thanks for the idea's guys.
Old Dec 12, 2001 | 08:26 AM
WICKED2's Avatar
New User
try using 10w-30 and don't use any synthetic oil for now.
vtec won't throw any code if u have a low oil pressure the only thing that will lite up would be u'r oil but for now try using a thicker oil
Old Dec 12, 2001 | 09:21 AM
Greyout's Avatar
Default Re: Vtec not engaging.. (WICKEDII)
when you ran out of oil, is it possible that the little pins in the VTEC engaging thingies fucked up?
Old Dec 13, 2001 | 09:46 AM
WICKED2's Avatar
New User
ders noway dat pin will get ****
da pin u'r talking about pressure activeted......oil pressure will go up to vtec pin or vtec switch den da vtec will engaged
HondacivDX
Feb 19, 2012 06:52 PM
MumBleZ_94gsR
Jul 18, 2009 10:47 AM
AXZ NYC
Feb 13, 2005 09:07 AM
CompressionFed
Mar 23, 2004 04:54 AM
gsrhatch530
Mar 28, 2002 01:36 PM
