oil breather
the one on the timing belt side goes to the fitting directly above it on the block, sticks out of the block like 2". then the one on the tranny side goes up to the intake mani between cyl 1+2 to the pcv valve. the other side of the pcv valve goes to the intake manifold.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KraZEtEggIE »</TD></TR><TR><TD CLASS="quote">the one on the timing belt side goes to the fitting directly above it on the block, sticks out of the block like 2". then the one on the tranny side goes up to the intake mani between cyl 1+2 to the pcv valve. the other side of the pcv valve goes to the intake manifold. </TD></TR></TABLE>
THANKS
THANKS
