Help!!!!! trouble with rear tranny bracket on swap
Old May 1, 2004 | 01:23 PM
coot_er's Avatar
Default Help!!!!! trouble with rear tranny bracket on swap
im installing a b16 from the top. i can get the right side and left side mounted but i can't get that bracket in on the back. i had just the drive's side mount on and couldn't get that bracket in place so now i have on just the right side tranny and i still can get that damn bracket in. I cant get it on the engine OR on the rear mount! please help!!!!
Old May 1, 2004 | 01:26 PM
RCautoworks's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (coot_er)
What engine bracket are you using ? Could it be the wrong one ?
Old May 1, 2004 | 04:52 PM
coot_er's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (90blackcrx)
its the engine bracket that came on the b16.
Old May 1, 2004 | 05:40 PM
spaceman's Avatar
what kind of car do you have?..its probably the wrong part.call hasport.com
Old May 1, 2004 | 05:43 PM
HatchBox's Avatar
Skoobie no more...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coot_er &raquo;</TD></TR><TR><TD CLASS="quote">its the engine bracket that came on the b16.</TD></TR></TABLE>
u cant use jdm mounts... need aftermarket mount kit
Old May 1, 2004 | 08:58 PM
coot_er's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (Hybrid Hatchback)
i have the three mounts from hasport and im using the the bracket ( kinda shaped like an L) that came on the b16 motor. it is a 91 Hf.
Please help
Old May 1, 2004 | 09:06 PM
nikkon's Avatar
Does the bracket curve to the left or right?U need the bracket that curves to the right.If it does u just have to play w/ the motor and wedge it in.If it is the one that curves right then get a bracket from 90-93 integra.
Old May 1, 2004 | 09:13 PM
nikkon's Avatar
my bad u nee the one that kicks to the left NOT the right
Old May 1, 2004 | 09:38 PM
coot_er's Avatar
Default Re: (nikkon)
how do i know if it is left or right curved? it came bolted on the b16, does that mean anything?
Old May 1, 2004 | 09:42 PM
coot_er's Avatar
Default Re: (coot_er)
it seems like my problem it that the mount is too big, it either hits the firewall or the engine. can i file the bracket or drop down the cross member?
Old May 1, 2004 | 09:51 PM
nikkon's Avatar
http://cgi.ebay.com/ebaymotors...=WDVW
Look at ur bracket,if it looks like this then u need a diffrent one.Look at the second pic of it,see how one side is straight and one side kicks off.
Old May 1, 2004 | 09:55 PM
Janos Lin's Avatar
Nah its the wrong bracket. You wouldnt be able to make it fit without a lot of damage Get the correct one which is for a 90-93 integra. You can either order it from an acura dealer, around 50 bucks or pull one from a junkyard. Found this out today myself, sigh. Trust me, we need to get the right bracket. Grinding on the bracket to get it to fit would only compromise the bracket and your engine's torque would twist it into a pretzel.
Janos
Old May 2, 2004 | 08:00 AM
coot_er's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (Janos Lin)
my bracket does not look like that one on the above post on ebay.on the top view mine curls the other way. so then this should be the right bracket? should i lower the crossmember and see what happens? the bracket definatly bolts up the the engine when its out side of the car, my problem is i can't fit it completely behind the engine. i would post a pic but i don't know how.
Old May 2, 2004 | 08:18 AM
sodacan33's Avatar
90-93 teg , get it , it will work!!!
Old May 2, 2004 | 08:38 AM
Janos Lin's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (sodacan33)
'k I gotta ask, do you have the instructions that came with the mount kits, and did you alter the rear crossmember as per the instructions? Involves hammering down on part of the rear crossmember so the bracket doesnt hit it.
So far I've been able to determine there might be 3 different kind of brackets, the 90-93 one, and the 94+ integra one, and there seems to be another one for 96+ Civic's which needs to use the 99 Si bracket I think.
Janos
Old May 2, 2004 | 09:45 AM
coot_er's Avatar
yes i did alter the rear cross member. after playing with it for another hour i see that my problem is that the back part of the bracket it hitting the support for the intake. it is only hitting by like a centimeter or two. i am 2 cm from setting the engine in !
Old May 2, 2004 | 09:55 AM
coot_er's Avatar
i think im going to lower my cross member and see if i can't get the bracket in place. sound like a good idea?
Old May 2, 2004 | 10:14 AM
HatchBox's Avatar
Skoobie no more...
on the rear crosmember thier is 2 sets of holes for the rear mount to bolt into...on the stock motor the mount is set in the passanger side set of holes, but on the b series u have to move the mount to the driver side set of holes for the mount...hope that made sence
Rear Crossmember:
________________
_____: :_________
Use the set of holes in the [ ]
________________
_____:[:]_________
*Front of car *
Old May 2, 2004 | 10:35 AM
coot_er's Avatar
i took the mount off just to see how the bracket would fit. even with the mount not even being there the bracket still will not slide in to were it needs to be in order to bolt on to the motor/tranny. its not that the bracket doesn't line up with the mount, the problem is i can't even get the bracket to fit in there right, even with the mount out.
Old May 2, 2004 | 01:53 PM
Janos Lin's Avatar
If its hitting the intake bracket, try and remove that? I mean im not sure if youre referring to the intake manifold support bracket, or the intake tube bracket. Any way you could post a photo of your current bracket?
Janos
Old May 2, 2004 | 05:12 PM
kanzenr91si's Avatar
is the bracket not bolted to the tranny yet? i bolted mine to the tranny first, then lowered it in. but if i understand you right, youre sayin the mount bracket is hitting the intake support, right? as in the bracket is not bolted to the tranny yet?
also pics would help a lot.
Old May 2, 2004 | 08:54 PM
coot_er's Avatar
Default Re: Help!!!!! trouble with rear tranny bracket on swap (kanzenr91si)
i got it i ended up taking the motor back out and putting the bracket in first.
Old May 2, 2004 | 09:07 PM
buster97
Apr 27, 2010 03:12 AM
Boosted_JDM
Apr 9, 2007 03:45 PM
EJ8 GSR-T
Apr 19, 2006 04:52 PM
corollagts33
Dec 7, 2005 10:37 PM
jDmImagE
Oct 15, 2005 01:18 PM
