cltuch/pressure plate problems...!!!
Old May 1, 2004 | 11:21 AM
92siracer's Avatar
Default cltuch/pressure plate problems...found it!
a friend of mine just test drove my car and when he came back it wouldnt go into or go outta gear. It will go into gear when the car is off but not when its on. and when i put it in gear when the car is off then start it the car jumps. and its makin funny noises. is my clutch/pressure plate gone????
found out the prob....i took it out and one of the springs broke off from the clutch. what causes this? someone mis-shifting or something??
Modified by 92siracer at 2:16 AM 5/3/2004
Old May 1, 2004 | 01:08 PM
tommymoose's Avatar
Default Re: cltuch/pressure plate problems...!!! (92siracer)
It could be the Clutch Slave Cylinder. I'm not sure what car you have, but with most Hondas its right infront and below the distributor.
Old May 2, 2004 | 09:10 AM
92siracer's Avatar
Default Re: cltuch/pressure plate problems...!!! (tommymoose)
its a 96 civic dx hatch wit gsr swap...i used the stock civic slave cylinder if that helps any.
Old May 2, 2004 | 05:35 PM
92siracer's Avatar
bump
92sully
Sep 6, 2010 01:18 PM
Lordofdark176
17
Dec 4, 2007 09:19 PM
nick91civicsi
Mar 17, 2007 09:47 AM
5ltreater
Apr 19, 2005 12:40 PM
93preludes
Aug 14, 2003 05:56 AM
