problems getting off oem springs
Old Apr 30, 2004 | 08:08 PM
W.O.P.'s Avatar
Default problems getting off oem springs
well i went to lower my car today and i couldnt get the ******* top nut off. i just kept twisting my allen wrenches. used pb blaster, and wd40. any other suggestions? i dont have air tools at home so is there any way out of the clouds and back to the road with my tegs height?
Old Apr 30, 2004 | 08:32 PM
eric8876's Avatar
Default Re: problems getting off oem springs (dohc VTEC eaaater)
look jus put in the allen key and spin the nut with the wrench, much easier...once it budges spray some rust remover and the rest will be a pieace of cake
When u get 2 tha back tell me if getting the bolt that connects the strut to the axle was easy to get off bcuz i got fuked there....good luck
Old Apr 30, 2004 | 10:03 PM
patmcd's Avatar
Default Re: problems getting off oem springs (eric8876)
My top nuts were rusted solid. No matter how much pb we used, they still wouldnt come apart. There are two options from here. If you have a nut cutting tool, then try that. Or you can just grind off the top of the shocks, nuts and all like i did.
Old Apr 30, 2004 | 10:56 PM
DC4noMore's Avatar
Default Re: problems getting off oem springs (patmcd)
Wow....I really hope your nut is rusted on or something because you talk alot of **** to not know that you have to use a wrench and an allen key.
Old May 1, 2004 | 06:42 AM
W.O.P.'s Avatar
Default Re: problems getting off oem springs (DC4noMore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4noMore &raquo;</TD></TR><TR><TD CLASS="quote">Wow....I really hope your nut is rusted on or something because you talk alot of **** to not know that you have to use a wrench and an allen key.</TD></TR></TABLE> umm READ my post you ******* idiot, i said my allen keys were twisting. so i WAS using a wrench and a allenkey. holy **** the n00bs stupidity is overwhelming
Old May 1, 2004 | 06:51 AM
IntEGNYC's Avatar
torch it!
Old May 1, 2004 | 06:52 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You sure you're using the right size allen key? Put the whole assembly on the floor and put the allen key in it, and have a friend stand on the assembly so that the allen key will hit the floor and can't go anymore, while you loosen with a wrench.
If it still won't budge, I would put it all back in the car and go somewhere that has air tools (if you don't have any) and get them to break those top nuts loose (not remove completely, just break them loose) then go back home and continue w/ the installation.
Old May 1, 2004 | 06:56 AM
W.O.P.'s Avatar
Default Re: problems getting off oem springs (PatrickGSR94)
thats what i think im going to have to do
Old May 1, 2004 | 07:39 AM
AspectIndustries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
If it still won't budge, I would put it all back in the car and go somewhere that has air tools (if you don't have any) and get them to break those top nuts loose (not remove completely, just break them loose) then go back home and continue w/ the installation.</TD></TR></TABLE>
Thats what I did.. I remove all 4 complete strut, and brought it to ANY mechanic shop, and just let them blast out the center nut with an AIR gun. They did it for free too..
Old May 1, 2004 | 08:37 AM
xSCTYGx's Avatar
Default Re: problems getting off oem springs (IntEGNYC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">torch it! </TD></TR></TABLE>
Old May 1, 2004 | 10:43 AM
natesgarage's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">You sure you're using the right size allen key? Put the whole assembly on the floor and put the allen key in it, and have a friend stand on the assembly so that the allen key will hit the floor and can't go anymore, while you loosen with a wrench.
Old May 1, 2004 | 01:31 PM
DC4noMore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc VTEC eaaater &raquo;</TD></TR><TR><TD CLASS="quote"> umm READ my post you ******* idiot, i said my allen keys were twisting. so i WAS using a wrench and a allenkey. holy **** the n00bs stupidity is overwhelming</TD></TR></TABLE>
You said nothing about using a wrench also, so you could have just had an allen key and were twisting the whole thing. And you're right I'm the noob here, you've only been a member for like 2 and a half months yet you have over 650 posts. Can you say post *****?
Old May 2, 2004 | 08:46 AM
W.O.P.'s Avatar
ha your right, i am a post *****...my posts give tech info 99% of the time. dumbass
*edit* your just worthless, please dont post in my threads again
Modified by dohc VTEC eaaater at 3:40 PM 5/2/2004
Old May 2, 2004 | 09:06 AM
IntEGNYC's Avatar
now now ladies... we wont have a fight here unless its with pillows.
Old May 3, 2004 | 07:20 PM
DC4noMore's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntEGNYC &raquo;</TD></TR><TR><TD CLASS="quote">now now ladies... we wont have a fight here unless its with pillows. </TD></TR></TABLE>
hahahaha
dohc wannabee coolboy : Yeah lots of tech info there buddy. Why don't you do a search on the stuff you post about and you'll change your mind there. What about the random alicia keys is hot post?, or the "take pictures of a porsche in a showroom and say hey guys i just bought a porsche" post. Those are just what i can remember off the top of my head, if I put any effort into it I know I could find more. Hahah shut up man your an idiot.
Old May 3, 2004 | 07:33 PM
Community Builder
alright alright, I have more posts and have been on here longer than anybody else in this whole thread, so let's just lay off and let him follow the advice I gave above.
JDM_CRX_PLEASE
Dec 22, 2007 09:24 PM
vinuneuro
Suspension & Brakes
Mar 4, 2007 12:02 PM
Zion-I
Aug 7, 2006 06:21 PM
baconcrx
Jun 4, 2006 03:31 PM
AzntaggeR
Feb 12, 2004 12:19 PM
