How do I remove the nut on Tokico Illumina shocks?
TSPeed Factory
like the title says. I used WD-40 and when i turn the nut the whole rubber upper piece turns too. even the screw that the nut is threaded around turns when i try to unscrew it.
just need to do this so i can replace the springs.
-also, i'm swapping out the springs for my coilovers. the springs are just plain yellow so maybe i thought they were neuspeed? can anyone help identify these springs?
Re: How do I remove the nut on Tokico Illumina shocks? (AzntaggeR)
Can you put an allen socket onto the top? If there is an allen, you can use that to hold the bolt and a wrench to take off the nut.
Or you can use an impact gun.
Re: How do I remove the nut on Tokico Illumina shocks? (Machine1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 »</TD></TR><TR><TD CLASS="quote">
Or you can use an impact gun. </TD></TR></TABLE>use an impact gun..its the fastest..and most easiest way ..
TSPeed Factory
nope, where the allen wrench would go is where you adjust the stiffness of the shock with a flathead. i don't have access to air tools so that's not an option. any other ways. i was thinking maybe wrapping a big piece of rubber around the threads and then holding it with a vice grip. any chance i could damage the threads by doing this?
No allen eh, bummer.
You can put a box-end wrench on the nut, then hit the end of the wrench with a hammer repeatedly. It's a trick I always use.
Combining that with the vice-grip idea could work, the rubber should protect the threads, just hope that it doesn't slip.
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">nope, where the allen wrench would go is where you adjust the stiffness of the shock with a flathead. i don't have access to air tools so that's not an option. any other ways. i was thinking maybe wrapping a big piece of rubber around the threads and then holding it with a vice grip. any chance i could damage the threads by doing this?</TD></TR></TABLE>
take the adjuster piece off and you can stick a allen key, i think you'll need a 6mm. impact is the fastest and
easiest but not the safest way to remove anything.
TSPeed Factory
Re: How do I remove the nut on Tokico Illumina shocks? (Mr. Choi)
alright. so how do i take off the adjuster piece? i tried to do it last night, but had no luck.
grab it with your finger nails or get a small flathead screwdriver and put it at the outside edge where the red plastic meets the shaft of the strut. it slides staight out though it may be a little tight.
TSPeed Factory
Re: How do I remove the nut on Tokico Illumina shocks? (nub)
thanks, but i already did it. you take off the red adjuster piece with needle nose pliers and it just slides off. and u slip an allenwrench inside there.
