unknown problem PLEASE HELP!!!!!
Ok my car is acting really strange and im not sure what it is or exactly how to describe it but ill try my best. I was just pulling into my neighborhood on my way home and as i pressed on the gas the car moved verrryyyy verrrryyyy slow and slugishly. The exhaust tone was kind of muffled and it was like this for the first 3-4k rpms, then it would go back to normal. When i pulled into my driveway the idle was a bit rough, but was staying steady at about 800rpm. The car has been perfect up to this point and I wasnt driving it hard so i dont know what it could be? The best way i could explain this is it feels/sounds like im starting my car off in 4th gear but im not. Please respond with feedback asap bc right now no one is up at my shop so i have no where else to go!
I had something exactly like this, i even thought exhaust being clogged. Then i started getting paranoid and ****, i was going crazy. Check out my post: https://honda-tech.com/zerothread?id=792436 If it sounds the same then your timings off. Took me 3 ecus and a good couple hours with another H-T member to figure it out but it was timing.
Later it happened again and it was a vaccum hose coming loose. So look for a vaccum leak, and check your timing.
Edit: i just saw your sig and saw your tuned. So just check for leaks.
k i figured out the problem - i needed to replace my spark plug wires, distrubutor cap & rotor.....just basic tune up shiz i shoulda done when i got the swap
Anyways guys thanks for your help!
tuan...
10
May 10, 2004 01:46 PM
