running open header
Old Apr 29, 2004 | 07:12 PM
SLR ef9's Avatar
Default running open header
i've got a b16 in my integra with bolt-on just wondering if it's worth running open header. Is there a noticeable difference in power verus an exhaust
Old Apr 29, 2004 | 09:31 PM
SeanEF's Avatar
Default Re: running open header (alphaprojectb16teg)
No its just loud..you can actually lose power.
Old Apr 30, 2004 | 05:13 AM
Jokerluv's Avatar
depends on your set up
Old Apr 30, 2004 | 08:33 AM
SeanEF's Avatar
Default Re: (Jokerluv)
I said you could lose power cause he has just bolt-ons...
Old Apr 30, 2004 | 09:00 AM
hybridEj6's Avatar
Default Re: (Sulli)
Definitly loose power
If you had a built head and were spinning that thing to 8kplus then you would benifit from it
Old Apr 30, 2004 | 10:31 AM
SLR ef9's Avatar
Default Re: (ekhybrd)
thanks for the advice. I do shift at 8k to scared to go any higher on stock head
Old Apr 30, 2004 | 07:02 PM
allout_eg6's Avatar
yeah you would lose power i had the same set up b16a1 in a red da straight header with bolt on's i was at mountain house all the time but anyways you need back pressure for b16a's not much torque especially in an integra.
Old Apr 30, 2004 | 07:04 PM
SeanEF's Avatar
Default Re: running open header (allout_eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allout_eg6 &raquo;</TD></TR><TR><TD CLASS="quote">yeah you would lose power i had the same set up b16a1 in a red da straight header with bolt on's i was at mountain house all the time but anyways you need back pressure for b16a's not much torque especially in an integra.</TD></TR></TABLE>
WHAT??
Old May 1, 2004 | 03:16 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: running open header (Sulli)
quote I found..........
Some of the other considerations included holding the vacuum condition in the collector long enough to be used by the next cylinder to fire. This is achieved by, the length of the collector, which must be at least 25 inches long. If it were any shorter, after the pulse passed outside a high pressure wave would form and go back up into the system, negating the vacuum.
Old May 1, 2004 | 05:37 PM
roadawg's Avatar
Default Re: running open header (Mista Bone)
i have doubts it doesn't make HP running open header. I had to drive to the muffler shop when i first got the swap and let me tell you the thing felt quick! Once the cat, piping and muffler were all hooked up it felt choked.
When I go to the track soon I will make a pass running through the cat, etc... and one pass with open header and make a post about the difference.
Old May 2, 2004 | 08:18 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: running open header (hybrid honda)
I lost .2-.3 second on the juice running open header.
LOUD AS F**K!!!!!!!!
Car lost so much power NA and open header, I couldn't do my normal 2nd gear burnout.
Old May 2, 2004 | 09:20 AM
jdmsijdm's Avatar
ive been running open header for a while now, with a slightly built b16. i do have a straight pipe bolted on to the header, and this makes a world of difference vs. open header. The last few weeks though ive heard a strange gurgling noise coming out through the pipe. People around here are telling me its gonna get worse and worse till i get a muffler on there, and that my exhaust valves are gonna burn up? can anyone vouch for this?
Old May 2, 2004 | 08:49 PM
jdmsijdm's Avatar
anyone? why is it that whenever i post, the thread seems to just stop. i know im not that much of a dumb ***
Old May 3, 2004 | 08:56 AM
SLR ef9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">quote I found..........
</TD></TR></TABLE>so i is better to run a straight pipe about 30in long with no cat.
Old May 3, 2004 | 12:16 PM
jdmsijdm's Avatar
thats what im doing now, running a straight pipe 2.5 inches about 36 inches long or so, and im running some pretty good times. But people keep telling me im gonna burn up my exhaust valves. Im waiting for any input on this.
Old May 3, 2004 | 01:10 PM
bigchevy66's Avatar
Default Re: (jdmsijdm)
Don't worry about your valves, they'll be fine. As long as you don't run the car with the header off, or with a blown header gasket, then you'll be ok.
Rinsta
Jul 17, 2009 09:27 AM
Rinsta
Jun 24, 2009 01:48 PM
bonstokLS
Jan 16, 2009 03:35 AM
teg_95
Sep 15, 2008 03:55 PM
91redteg
May 8, 2007 10:44 AM
