929 ITB' Questions
Old Apr 29, 2004 | 04:45 PM
user 996328629's Avatar
Default 929 ITB' Questions
First off whats this... and should i use it, or cap it off?
Also in this pic there is the rocker arm of some sort, but one has a nut on it the other does not..normal?
Another view...
And last but not least, do you think ill benefit from porting these out ?
Old Apr 29, 2004 | 06:28 PM
Ryan C's Avatar
Default Re: 929 ITB' Questions (Swags04)
yeah, i had the same question.
its so ugly.
its an 'idle screw' if you twist it both ways you'll see holes where the horn open and close. i junked mine and i'm gonna fab somthin up that is a little less ugly
Old Apr 29, 2004 | 06:56 PM
Kendall's Avatar
What I'm doing is completely removing that system and allowing air to breath through the idle at all times.
Don't bother porting it, just get the OEM rubber connecting pieces (I don't know what they're called) and the inlet will perfectly match the throttle body side while the oulet will be perfectly round in order to mount them on to a piece of properly sized aluminum piping.
Old Apr 29, 2004 | 07:10 PM
Default Re: (Kendall)
But wont completly removing them allow to much air in?
Old Apr 29, 2004 | 07:13 PM
Default Re: (Swags04)
ANd also im not using the oem velocity stacks, (obviously) I need to also figure out a way to mount the stacks..
Old Apr 29, 2004 | 07:16 PM
Ryan C's Avatar
you can adjust it to where your comfortable with it then take it off
Old Apr 29, 2004 | 08:14 PM
Sliced Beard's Avatar
Default Re: (Ryan C)
or you can just mount it on the bottom to where nobody sees it
Old May 1, 2004 | 09:14 AM
Default Re: (dirtyd463)
Might be kinda hard to swap it all over..
Old May 1, 2004 | 03:42 PM
no i meant just install it upside down
nobody could tell the difference
the only thing i see bad about mounting it upside down would be the fact that it would be hard to adjust the idle
but once you get it set you should not have to worry about it again and it makes it look a lot cleaner
6footmidget
Sep 23, 2008 07:58 PM
hybridpatient95
Nov 14, 2004 03:16 PM
DelSolSi93
Sep 5, 2004 08:27 PM
redlineintegra
Jul 24, 2004 11:24 AM
91SE
Feb 18, 2003 04:35 PM
