Brake Conversion?
Old Apr 28, 2004 | 02:27 AM
4drCivicD2B's Avatar
Default Brake Conversion?
I am going to upgrade my brakes from drums to rotors. How difficult is it to do? Should I do it, or go to a shop?
Old Apr 28, 2004 | 02:30 AM
2lua's Avatar
Default Re: Brake Conversion? (4drCivicD2B)
easy, provided that you have all the parts, it's should take half a day. or how ever long it take you to do it. just take your time.
Old Apr 28, 2004 | 05:26 AM
Default Re: Brake Conversion? (2lua)
Thanks for the help. I was assuming that it wouldnt be difficult, but I didnt want to get into something that I couldnt finish. I already have the parts, I got front and rear gsr, it is just that I am in Italy now, so I wasnt sure if it was a sure shot, because I have yet to look at it. Thanks again!
Old Apr 28, 2004 | 05:30 AM
wilsel's Avatar
Go here http://tech.hybridgarage.com/tech/brakeswap.html
Old Apr 28, 2004 | 05:32 AM
MAKAROV's Avatar
its pretty easy , but the front might be the same already dont waste your time, my 97 ex front brakes are the same as the gsr i just converted the rears
Old Apr 28, 2004 | 06:28 AM
Default Re: Brake Conversion? (wilsel)
Great site! thanxs.
Oh, I need to replace the front anyways, they are in need of it. Thanks for the help!
Old Apr 28, 2004 | 06:42 AM
Luserkid's Avatar
Only problem youll run into is probably E brake cable, other then that youll have a harder time finishing a 12 pack of long necks (in one sitting) then doing this swap.
Old Apr 28, 2004 | 07:24 AM
Ricey McRicerton's Avatar
Default Re: Brake Conversion? (Luserkid)
There are quite a few writeups. I know I did one, as well as =GAMEOVA= and possibly others.
Mine, showing how to put 4x114.3 brakes on (same thing as 4x100)
https://honda-tech.com/zerothread?id=811892
=GAMEOVA='s thread.
https://honda-tech.com/zerothread?id=812062
Better than mine. You should use his as a step by step. Mine is just more helpful as far as 4x114.3 parts.
Frank_ej6
Suspension & Brakes
Dec 23, 2014 05:59 PM
FGride
May 25, 2006 12:46 PM
Hybridhonda561
11
May 21, 2002 12:25 PM
TruePlayaz114
Feb 24, 2002 08:01 PM
