SRS light on
Old Apr 27, 2004 | 10:05 PM
xTravBx's Avatar
Default SRS light on
Im looking at a 95 EG.. and SRS is on.. is this normal?
Old Apr 27, 2004 | 10:13 PM
skip.two's Avatar
Default Re: SRS light on (xTravBx)
airbag plugged in?
xTravBx's Avatar
Default Re: SRS light on (jL iLLuZiOnz 9)
have any pics of where this plug is, so i can check?
Old May 8, 2004 | 02:50 PM
thrty8street's Avatar
i just took out my cd player and now the light comes on too, i tried putting it back in but its still on. im getting pretty frustrated
Old May 9, 2004 | 09:28 AM
hey im at the last step where the light blinks twice on and off; then i turn off the ignition.
But after i start the car again, the light wont go off, can some help me
Old May 9, 2004 | 10:00 AM
TorganFM.'s Avatar
Default Re: SRS light on (thrty8street)
That means that something is still wrong with your SRS system. The MES reset only works if everything that was wrong with the SRS system was fixed (plugged in, etc).
Old May 9, 2004 | 10:03 AM
Simple's Avatar
Default Re: SRS light on (DanW)
Directions for erasing memory on SRS light
1st you need to either buy or make the "SCS Service Connector." I used a speaker harness for and older Honda which you can buy at a local stereo shop such as Circuit City or Best Buy, and cut the wires and looped them together. You can also use a paperclip but that will make it a little more difficult because you have to connect it and disconnect it a few times quickly.
2nd you need to find the MES (Memory Erase Signal) connector
It is a yellow connector with two wires in it that is plugged into the fuse box, unplug it and pull it down. Once you have done that you can begin the process of erasing the memory. NOTE: This will only reset your SRS System if what caused it to trigger has been fixed, Ex: turning the ignition on with any SRS Plugs disconnected, such as pulling your seat out.
1st step in erasing the memory is to turn the ignition off and connect the SCS Service connector to the MES Plug,
2nd Turn Ignition on. SRS indicator light will come on for about 6 seconds then go off.
3rd Disconnect SCS service connector for MES connector within 4 seconds after SRS indicator light goes off. SRS indicator light will come on again.
4th Reconnect SCS service connector the MES connector within 4 seconds after SRS light comes on. SRS indicator light will go off.
5th Disconnect SCS service connector from MES connector within 4 seconds. SRS indicator light will indicate that memory is erased by blinking 2 times.
6th Turn ignition off, and wait 10 seconds. Start vehicle like normal and light should come on and go out like normal. You have reset your SRS light, congrats.
If it does not work the first time try it again, the timing has to be perfect. My first time it took me 3 attempts before it worked, but it did work.
(quoted from http://www.teamdelsol.com)
Old May 9, 2004 | 10:16 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">That means that something is still wrong with your SRS system. The MES reset only works if everything that was wrong with the SRS system was fixed (plugged in, etc).</TD></TR></TABLE>
what could possibly be wrong? i dont understand
Old May 9, 2004 | 10:18 AM
TorganFM.'s Avatar
I don't know. Did you unplug anything else while taking the cd player out? the SRS harness goes from each side of the car to the middle and down behind the center console. Check all the connections on that yellow harness.
Old May 9, 2004 | 10:26 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DanW &raquo;</TD></TR><TR><TD CLASS="quote">I don't know. Did you unplug anything else while taking the cd player out? the SRS harness goes from each side of the car to the middle and down behind the center console. Check all the connections on that yellow harness.</TD></TR></TABLE>
yes i unpluged this harness located down the middle of the console like you said. its pretty big about 2 inches long. i think i started the car with this disconnected and that is when the srs light came on. its now pluged back in but it still stays on after completing all the steps.
Old May 9, 2004 | 11:47 AM
it worked but when i turn off the car, and turn it on again, the srs light is back on. help please. i checked and everything is connected.
Old May 9, 2004 | 01:41 PM
up
Old May 9, 2004 | 01:49 PM
Chiovnidca's Avatar
What code does it have stored?
Old May 9, 2004 | 02:08 PM
Default Re: SRS light on (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">What code does it have stored?</TD></TR></TABLE>
how do i know where to find this?
undrh2o
10
Dec 19, 2009 11:42 AM
StolenTeg
Nov 28, 2004 08:19 AM
aznrexboi00
Jan 30, 2004 09:00 AM
DumpedSi
Sep 11, 2003 08:42 PM
White S2k
Oct 16, 2002 03:16 PM
