what kinda valves??
Old Apr 27, 2004 | 09:52 PM
91ls-v's Avatar
Default what kinda valves??
what kinda valves should i used with crower stage 2 cams??
would my stock bottom end be able to make power with the cams?
i almost 4got i have a b18a
Old Apr 27, 2004 | 10:13 PM
Rick Solis's Avatar
Default Re: what kinda valves?? (91ls-v)
JG, Supertech, SI, REV, Ferrea and crower all have decent valves. guess it really all comes down to budget and personal preference
Old Apr 27, 2004 | 10:15 PM
91ls-v's Avatar
i'm pretty much on a tight buget...so whats the cheapest out of all of them.
will my stock bottom end blow if you only do those 2 mods with adjustable cam gears?
sorry for such a newbie question
Old Apr 27, 2004 | 10:30 PM
Rick Solis's Avatar
Default Re: (91ls-v)
you dont really need valves, you can get by with stock. You do need to go with a decent spring/retainer set up though. And yes, they will make power with your stock bottom end. A little compression will always help though
Old Apr 28, 2004 | 01:10 AM
ExospeedAMcrx's Avatar
stainless steel valves arent much. you can go with an oversize or standard size. we charge only about $200 depending on the type of head.
Wil
Old Apr 28, 2004 | 02:23 AM
jcxcrxsi's Avatar
Default Re: (exospeedAMcrx)
would my d16a6 valves fit in a zc, and if not how much could i get them for (zc)?
Old Apr 28, 2004 | 04:20 PM
91ls-v's Avatar
thanx..but my bro's friend told me that i would need valves or else i might bend my old ones...and blow my head and bottom end..he builds his own motors and it's pretty fast so i kinda believe him but would like more opinions on it first thanx
Old Apr 28, 2004 | 04:29 PM
Rocket's Avatar
If you are an LSVTEC with a stock B18a bottom end becareful because the valve reliefs on LS pistons are smaller and you may have piston-to-valve clearance issues with bigger cams and running the intake advance on the cams.
This becomes even more of a problem when the head is milled since the bottom edge of the intake valves will come really close to the top edge of the valve reliefs. Also not runing properly located dowel pins for the head can also become problematic.
Old Apr 28, 2004 | 07:09 PM
91ls-v's Avatar
umm...at the first post i said i had a b18a...not an ls-vtec
sorry if the user name mislead you
Old Apr 29, 2004 | 01:01 AM
Rocket's Avatar
Ah your cool then.
Old Apr 29, 2004 | 01:05 AM
Joseph Davis's Avatar
Default Re: (jcxcrxsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jcxcrxsi &raquo;</TD></TR><TR><TD CLASS="quote">would my d16a6 valves fit in a zc</TD></TR></TABLE>
What makes you think SOHC valves would fit into a first generation LS engine?
(Yes, that was a hint)
Old May 12, 2004 | 01:55 AM
nevamind's Avatar
Default Re: (J. Davis)
Let me guess????? a ZC is in D series family, but Dohc instead of Sohc. Correct me if I'm wrog.
Boner_Ben
25
Jan 19, 2006 08:05 AM
Big Josh
May 8, 2003 09:03 PM
Allstar
Apr 30, 2002 07:54 PM
