type r ecu
NO.
#1 ITR ECU's have immobilizers that have to be removed, and when they are, you get a constant CEL
#2 That ECU is designed for a 1.8L and not a 1.6L...different fuel maps
#3 The cams are different as well, again different fuel maps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">*What he said*</TD></TR></TABLE>
Not to mention, the fuel cutoff is about 400 RPM higher than it should be for a B16A2.
Good luck floating valves . . .
VTEC crossover is also set wrong for a B16A2. You'd be better off with a V-AFC instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">NO.
#3 The cams are different as well, again different fuel maps</TD></TR></TABLE>
Learns from friends
BUT TYPE R MAKES JOO MAD FIZZAST
-sander
Learns from friends
-sander
an adittion to #1, 97-98 usdm p73 itr ecu's did not hav an immobilizer from what i've heard. can anyone confirm this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starbury »</TD></TR><TR><TD CLASS="quote">i got a 2000 si swap, someone is offering me a type r ecu, whats the street price on them so i know that this guy isnt tryin to rip me off and is it worth it?</TD></TR></TABLE>
Want a 99-00 Si ECU??? I just might know someone who has one lying around. (me)
Shoot me a PM if interested.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kid1320 »</TD></TR><TR><TD CLASS="quote">ok.... what about visversa? ITR motor with a 2000 Si ecu?</TD></TR></TABLE>
Same principal applies. 1.8 motors need 1.8 ecu. You "can" do it but you need to move a fuel pump pin (to a15, i think) and you car will run like ***.
-sander
-sander
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cre18 »</TD></TR><TR><TD CLASS="quote">
an adittion to #1, 97-98 usdm p73 itr ecu's did not hav an immobilizer from what i've heard. can anyone confirm this?</TD></TR></TABLE>
Don't know if this helps ya but a buddy of mine has 3 98 ITR's (yes, actual whole running cars) and all 3 of them have immobilizers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander »</TD></TR><TR><TD CLASS="quote">
-sander</TD></TR></TABLE>
my car funs fine without doing anything
pass smog too
just wondering if there were ill sided effects from it.
pass smog too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by starbury »</TD></TR><TR><TD CLASS="quote">i got a 2000 si swap, someone is offering me a type r ecu, whats the street price on them so i know that this guy isnt tryin to rip me off and is it worth it?</TD></TR></TABLE>.
By any chance are the offering a civic type r ecu?
pass smog too
just wondering if there were ill sided effects from it.</TD></TR></TABLE>
Oops your right, thats what you have to do to use a p2t in an integra. My bad.
You really should try an ecu equipped for a 1.8 (if im assuming correctly thats what you have). I am willing to bet youll be very satisfied
-sander
pass smog too
-sander
faststkSi34
Sep 27, 2004 11:32 AM
