type R ecu???
Old Jul 10, 2003 | 11:58 PM
si foo's Avatar
Default type R ecu???
Hey I have a 98 gsr, I was wondering if a 98 type R ecu will fit without CEL or anything else going wrong. Is it a good upgrade? Should I?
Old Jul 11, 2003 | 12:03 AM
B16OnTop's Avatar
Default Re: type R ecu??? (si foo)
why dont you just chip your GSR ECU? or go OBD-1?
Old Jul 11, 2003 | 12:10 AM
si foo's Avatar
Default Re: type R ecu??? (B16OnTop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">why dont you just chip your GSR ECU? or go OBD-1?</TD></TR></TABLE>
I have the type r ecu sitting here, it's just sitting...nothing to do with it.
Old Jul 11, 2003 | 12:14 AM
B16OnTop's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si foo &raquo;</TD></TR><TR><TD CLASS="quote">
I have the type r ecu sitting here, it's just sitting...nothing to do with it.</TD></TR></TABLE>
oh i did not know that; my bad
Old Jul 11, 2003 | 01:52 PM
si foo's Avatar
good upgrade? any problems?
Old Jul 11, 2003 | 02:05 PM
Cramerox's Avatar
the itr ecu wont open up the first stage of vtec. might be just a waste unless you plan on getting a new mani
Old Jul 11, 2003 | 02:10 PM
MooreBoost's Avatar
Default Re: type R ecu??? (Cramerox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cramerox &raquo;</TD></TR><TR><TD CLASS="quote">the itr ecu wont open up the first stage of vtec. might be just a waste unless you plan on getting a new mani</TD></TR></TABLE>
You mean the secondaries? I didnt know ITR manis didnt have secondaries.
gmoore
Old Jul 11, 2003 | 02:13 PM
Cramerox's Avatar
Default Re: type R ecu??? (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">
gmoore</TD></TR></TABLE>
Yeah secondaries. ITR have different mani design.
Old Jul 11, 2003 | 02:19 PM
MooreBoost's Avatar
Hmm, ok.
gmoore
Old Jul 11, 2003 | 02:32 PM
NeoGSR's Avatar
it won't send the signal for the secondaries as in the p72 ecu.....
first part of vtec eh???
Old Jul 11, 2003 | 02:40 PM
Henry HA's Avatar
HAnda-Tech Member
Default Re: type R ecu??? (NeoGSR)
Type r ECU wont open the GSR secondary runners on the IM, not the first stage of vtec..
Old Jul 11, 2003 | 02:42 PM
Harry_Randal's Avatar
Default Re: type R ecu??? (B18C_DC2)
Well I am sure if you have the R ecu sitting you can find someone that would either buy it or trade for a OBD1 ecu... I would say reprogram your stock, try getting some money out of the R ecu.
Old Jul 12, 2003 | 01:41 AM
si foo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_DC2 &raquo;</TD></TR><TR><TD CLASS="quote">Type r ECU wont open the GSR secondary runners on the IM, not the first stage of vtec..</TD></TR></TABLE>
is this good or bad? should i still put the type r ecu or not. My 98 teg is just a beater and to drive ppl around it a 4 door gsr. Just since i have a type r ecu setting around. It came with the motor b18c5 which is sitting around too. since the motor's not going in a car I have the ecu to play with, that's y I can't sell the ecu for a obd1... Just trying to understand if put the ITR ecu is GOOD or BAD...
Old Jul 12, 2003 | 08:34 AM
ARACER25's Avatar
It will not help you if your car is stock in fact it will hurt performance because like the others have said the P-73 will not open the secondary intake runners. However if you change your intake manifold then it would work. Not that you would see much difference other than a higher redline which is not advisable with a stock valvetrain.
Old Jul 12, 2003 | 01:59 PM
si foo's Avatar
Default Re: (ARACER25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ARACER25 &raquo;</TD></TR><TR><TD CLASS="quote">It will not help you if your car is stock in fact it will hurt performance because like the others have said the P-73 will not open the secondary intake runners. However if you change your intake manifold then it would work. Not that you would see much difference other than a higher redline which is not advisable with a stock valvetrain.</TD></TR></TABLE>
Cool thanks man finally a simple answer...
Old Jul 21, 2003 | 03:05 PM
ARACER25's Avatar
Default Re: (si foo)
Do you still have the P73 ECU and if so can you post or send me pics. I just bought one and its not what I thought as far as the pin locations.
MinnesotaTuner
Nov 1, 2015 10:02 PM
mugentype-r
Nov 2, 2005 02:49 AM
TheMuffinMan
Aug 13, 2005 06:09 AM
MiguezVTI
Sep 2, 2004 10:17 AM
ViperbitGSR
Jul 9, 2003 10:13 PM
