LS won't start in 99 SI
Old Apr 27, 2004 | 02:05 PM
gsrhatch530's Avatar
Default LS won't start in 99 SI
I just put a B18b1(99) into my 99 SI and it wont start.
The fuel pump is coming on. The starter is good. The starter, wiring harness, and the engine itself are all grounded.
The starter doesn't even kick over. It acts as if the battery were dead but I had jumper cables from my truck to the battery and it still wouldn't kick the starter.
Any ideas. It maybe something obvious so any reply is better than none. Thanks
Old Apr 27, 2004 | 02:24 PM
91DA9's Avatar
Default Re: LS won't start in 99 SI (gsrhatch530)
Have you tried running a hot wire directly to the starter solenoid? If it still doesn't crank after that it is most likely the starter.
Old Apr 27, 2004 | 04:52 PM
Default Re: LS won't start in 99 SI (91DA9)
We tried that as well and nothing. The starter is off my b16a2. I worked fine a few weeks ago.
Also when I jump it off my truck the fuel pump turns on, without the key in the ignition. Is this normal?
Old Apr 27, 2004 | 10:24 PM
H2nr's Avatar
try to turn the crank over by hand. does it move?
Old Apr 28, 2004 | 02:20 PM
Default Re: LS won't start in 99 SI (H2nr)
They crank moves. I put a socket on there and it turned fine. I did that before I put the engine in.
Old Apr 28, 2004 | 03:17 PM
havok hybrid's Avatar
DUH!.. is the single wire hooked up to the start.... The starter signal wire... is it hook up ... .
its black and has a stripe on it.. and has a female connector on the end of it...
get back to us ..
Old Apr 28, 2004 | 04:00 PM
Default Re: LS won't start in 99 SI (havok hybrid)
yeah it is hooked up.
killaberna
Sep 9, 2015 07:56 PM
unACCORDInated
Aug 26, 2010 03:34 AM
twentyhurtz
Nov 8, 2009 06:29 PM
OPTION2ek V.2
Jul 18, 2005 10:05 PM
porkchop14
Sep 28, 2004 09:10 AM
