How do you remove the residue left from old window tint?
Old Nov 1, 2001 | 08:49 AM
skafia's Avatar
25 Year Member
Default How do you remove the residue left from old window tint?
I tried rubbing alcohol but that **** just smeared it all around!
Old Nov 1, 2001 | 08:50 AM
MugenRD1's Avatar
Default Re: How do you remove the residue left from old window tint? (skafia)
put some windex and take the residue off with an razor blade !
Old Nov 1, 2001 | 09:25 AM
TurBoTeG's Avatar
Default Re: How do you remove the residue left from old window tint? (MugenRD1)
Try this stuff called Goo Gone...i dunno if it will work but its worth a try
Old Nov 1, 2001 | 09:38 AM
HiRevn's Avatar
Ammonia will usually get that stuff off.
Old Nov 1, 2001 | 10:05 AM
Aceman64's Avatar
any cleaner and a little scrub pad like for dishes. worked for me.
Old Nov 1, 2001 | 12:44 PM
PM-Performance's Avatar
Default Re: How do you remove the residue left from old window tint? (Aceman64)
a razor blade and some patients . . . . . . . it sux bro , did you get pulled over?
watch out if your taking the rear window off. might pull up the defrosters
Old Nov 1, 2001 | 12:47 PM
Reverend's Avatar
Default Re: How do you remove the residue left from old window tint? (itr206)
is there anything that takes it off without damaging the rear defrosters?
Old Nov 1, 2001 | 01:10 PM
GSR2001's Avatar
Default Re: How do you remove the residue left from old window tint? (HiRevn)
No doubt Amonia will take that glue off real fast
Old Nov 1, 2001 | 11:56 PM
masterxfob's Avatar
dude, that sucks! i got pulled over in Thousand Oaks a while back but never had to take my tint off, they just made me pay a $77 fine. it was unbelievable, there was a black S500 with 5% tint, red 3000GT with 5% tint, and my red GSR with 35% tint, we we're cruising at the same speed and the pig pulls me over out of the bunch.......
Old Nov 2, 2001 | 12:27 AM
MintyDip's Avatar
Default Re: How do you remove the residue left from old window tint? (TurBoTeG)
GOO GONE is the SHIET!!!!!!!!!
it takes everything off
it took off my friends honda signs by just dripping it on and moving the sing around
has cleans many things for me too
Old Nov 2, 2001 | 12:42 AM
masterxfob's Avatar
Default Re: How do you remove the residue left from old window tint? (MintyDip)
wouldn't that stuff harm the paint/clear coat on the car?
and when are you getting your comptech swaybar kit? i might want to take your itr sway bar setup!
Old Nov 2, 2001 | 09:42 AM
MintyDip's Avatar
Default Re: How do you remove the residue left from old window tint? (masterxfob)
im trying to sell the itr sway bar kit to a friend, but if it doesnt go through, ill post it in the classified
i was gonna sell it to him 110 installed
as soon as i get sell it and get $$$ i get comptech
Old Nov 2, 2001 | 10:16 AM
wuhungsixxx's Avatar
New User
or GOOF OFF...!...hehe
Old Nov 2, 2001 | 10:24 PM
joesosilly's Avatar
Default Re: How do you remove the residue left from old window tint? (wuhungsixxx)
ammonia........lots of ammonia but use it in a well vented area!
Old Nov 2, 2001 | 10:43 PM
skafia's Avatar
25 Year Member
Default Re: How do you remove the residue left from old window tint? (joesosilly)
I don't think I wanna be chilling in my trunk swiping ammonia all around--not much air circulation.
No, my window tint started to peel off (previous owner) it looked tacky cause it separated in 2 places so I just peeled it off. My defrosters are fine, just the gooey residue is left over.. i've heard people using a razor blade so I'll try that, thanks!
Old Nov 3, 2001 | 07:22 AM
joesosilly's Avatar
from my exp, dont use razors windex or goo gone cause it wont do the trick. the best method is to spray the ammonia on the glass itself and cover glass with plastic bags. just let it soak in for a few mins. the longer you wait the easier it will to take off the glue. also, when its done without being rushed you can peel the glue off the glass with minimal effort. my defroster still works!
Old Nov 4, 2001 | 07:10 AM
RICEBURNER1406's Avatar
New User
goof off and some razor blades and patience
Old Nov 4, 2001 | 08:22 PM
Integls's Avatar
Default Re: How do you remove the residue left from old window tint? (RICEBURNER1406)
50/50 Ammonia, Rubbing alchohol Mix... Its What all the tint shops use...
Do as somone else suggested and let it sit several hours with a bag around it... den scrub away...
Old Nov 8, 2001 | 07:27 AM
skafia's Avatar
25 Year Member
Default Re: How do you remove the residue left from old window tint? (Integls)
How bout I just take it to a window tint shop, have them remove it and tint it again while they're at it?
Old Nov 8, 2001 | 08:32 AM
wusta515's Avatar
New User
sup yo....i removed that stuff last week with 3M adhesive remover. You can get it at most auto parts store. Works pretty good. Remember, this is very time consuming. Took me like 2 hrs or more to do the 2 little rear windows on my hatch in my g2 integ. Just keep spraying and keep wiping. I went over it at the end with Armorall Window cleaner. Hope this helps... peace
Old Nov 8, 2001 | 10:18 AM
mr2's Avatar
mr2
razor blade and blow dryer.. wait that was for grip tape .. it might work!
Old Nov 11, 2001 | 01:41 AM
speedymon's Avatar
Default Re: How do you remove the residue left from old window tint? (white eg)
I took mine to a tint shop and they did it for 20 bucks. It came out clean as hell and they didn't mess up the defroster. Welll worth the $20, too much hassle.
Old Nov 11, 2001 | 09:02 AM
Max GSR's Avatar
No, NO, REALLY, the BEST (and cheapest) solvent is regular old lighter fluid! It leaves NO resudue, is clean, and works the nuts!!
DA jeshy
Jan 31, 2006 08:23 AM
Kimbo
11
Mar 31, 2004 12:01 PM
alfaaay
Aug 2, 2003 05:56 PM
Superdragr45
Apr 8, 2003 08:53 PM
Fascion
Acura TL, RL & ZDX
Jul 15, 2002 02:35 AM
