Brake Caliper Semi-Stuck
Old Apr 27, 2004 | 08:50 AM
Ricey McRicerton's Avatar
Default Brake Caliper Semi-Stuck
Okay guys, ever since I did my 4x114.3 swap my rear drivers side caliper has been a bastard. It doesn't adjust correctly.
I compress the actual part that pushes agianst the pads down as low as it will go (which is about 1/8 of an inch further out of the caliper than the "good side". Everytime I try to press the brake pedel to "adjust it", it damn near locks my brake up. I can barely spin it with my hands when the rim is off of it. Anybody have any ideas how to fix this? It's about to drive me nuts. Nowhere around here can get me a caliper rebuild kit and I'm not trying to shell out another 100+ dollars for a new Nissin caliper if I can help it.
Old Apr 27, 2004 | 08:58 AM
DAguyLS's Avatar
ricey, i just did this yesterday
mine was the same, i couldn't compress the piston all the way.
i just went to the junkyard and my boss let me rip off a caliper and only charged me 10 bux.......just get a used one.....it'll work
Old Apr 27, 2004 | 09:14 AM
Default Re: (slamdcivic)
Not going to happen around here. There isn't a junkyard in 100 miles that's going to have a rear disc caliper and I need it for this weekend. ****.
Old Apr 27, 2004 | 09:17 AM
DAguyLS's Avatar
i sprayed PB blaster all INSIDE the rubber boot around the piston and it helped me compress the piston further.
try putting a wrench flush against the piston and then use a C-clamp on one side of the caliper and the other side on the wrench
this will more evenly distribute force around the piston
Old Apr 27, 2004 | 09:42 AM
Built to Spill's Avatar
el diablo
We gotta drive to Charlotte on friday...try that junkyard on Highway 70 they always have alot of foreign chit.
City Auto Salvage
USHighway 70, Raleigh, NC 27601
(919) 834-9242
Old Apr 27, 2004 | 10:15 AM
1fastVX's Avatar
Default Re: (Built2Spill)
Correct me if I am wrong, but I am sure you need to spin the brake piston on the rear calipers to get it to go in. You cant use a c-clamp to compress it in. You can see a pic and description of the tool in the link below.
http://www.thetoolwarehouse.net/shop/KD-3163.html
John
Old Apr 27, 2004 | 10:17 AM
Default Re: (1fastVX)
Yes, you do have to spin them to compress them. Once I get it about 1/8 of an inch from being compressed fully into the caliper it just spins and doesn't go in anymore. Looks like I'll have to call around some more.
Yeah Richard, I'm trying my best to get it fixed before Friday night.
EDIT: No luck on ANY of the junkyards around here. Anybody know of any Autozone type places sell rebuilt Nissin calipers? Last place I checked (autozone) doesn't.
Modified by Ricey McRicerton at 2:35 PM 4/27/2004
Old Apr 27, 2004 | 10:27 AM
DAguyLS's Avatar
my bad, i thought we were speaking in terms of the front caliper......i re-read and now stand corrected
swtch7
Mar 11, 2009 06:40 PM
IntegraType-R
Jul 31, 2007 09:11 AM
leviq
Jul 7, 2007 08:28 AM
Ninja Mike
May 27, 2004 07:20 PM
KhRoNiX
Dec 19, 2001 10:18 AM
