NX nitrous kit on a SOHC vtec
Old Apr 26, 2004 | 03:08 PM
BlendedEJ8's Avatar
Default NX nitrous kit on a SOHC vtec
i work at a car dealership and we have to take off all the xtra stuff people put on there cars. i.e: alarms, nitrous kits, etc... well i got a 03 rsx (type s i believe didnt really pay much attention to it all) in with a 10lb. NX system et up for a 50hp shot. would this be applicable to my car with little/no modifications and just outta curiousity, anyone running a nitrous feed on ur SOHC vtec??? pros. and cons. of nitrous?? i dont know much about juice,. thanks in advance H-Techers. holla
Old Apr 26, 2004 | 03:38 PM
94civicNewbie's Avatar
Default Re: NX nitrous kit on a SOHC vtec (GreaseMNKY)
https://honda-tech.com/zerothread?id=830530
https://honda-tech.com/zerothread?id=831387
The SEARCH button is a God.
Hope it helps.
Old Apr 26, 2004 | 04:09 PM
Discosteak's Avatar
Default Re: NX nitrous kit on a SOHC vtec (94civicNewbie)
wow you searched before the end of your trial period
Old Apr 26, 2004 | 04:12 PM
Default Re: NX nitrous kit on a SOHC vtec (BADEG6)
I believe that a good thing dont you?
Old Apr 26, 2004 | 04:28 PM
BlendedEJ8's Avatar
Hope it helps.[/QUOTE]
i know how to use search, im just lazy right now thanks
Old Apr 26, 2004 | 04:39 PM
RyanEJ8's Avatar
I've run a 55, 65, 75, and 100 shot on my D16Y8. I think you'll love it.
Old Apr 26, 2004 | 04:40 PM
Ricey McRicerton's Avatar
Default Re: NX nitrous kit on a SOHC vtec (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">I've run a 55, 65, 75, and 100 shot on my D16Y8. I think you'll love it.</TD></TR></TABLE>
This man knows his SOHC N20 stuff.
Old Apr 26, 2004 | 05:35 PM
BlendedEJ8's Avatar
ryancivic2000; u mind if i pm you to get more info.
Old Apr 26, 2004 | 05:46 PM
BlendedEJ8's Avatar
also, what is the diff. between wet and dry kits?? one is a direct injection through ur manifold correct??
Old Apr 26, 2004 | 05:53 PM
CivicSiRracer69's Avatar
Dry kit = a Single N20 fogger just spraying N20 thru your Intake tube
Wet Kit = a Fogger sytem using Both Fuel and N20 spraying together and premixing for combustion
Direct port = Putting Fogger into the Intake manifold Most comonly into the runners, Make sure you use the Y8 IM for high N20 doses Dude to the Larger DIameters of the Runners any more Q's? just ask!
Old Apr 26, 2004 | 07:46 PM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GreaseMNKY &raquo;</TD></TR><TR><TD CLASS="quote">ryancivic2000; u mind if i pm you to get more info.</TD></TR></TABLE>
Sure. Not a problem.
Old Apr 26, 2004 | 07:58 PM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicNewbie &raquo;</TD></TR><TR><TD CLASS="quote">I believe that a good thing dont you? </TD></TR></TABLE>
yes you are a good newb
Old Apr 26, 2004 | 08:08 PM
blackeg's Avatar
Default Re: NX nitrous kit on a SOHC vtec (SOHC_MShue)
might look into upgrading your clutch if you plan on spraying a good amount. i had the nx wet kit that i was going to use on my d16. i upgraded my clutch in anticipation of spraying, but i sold the nitrous and never used it.
FallenAngelHIM
Mar 10, 2006 07:03 AM
RexShop
Mar 19, 2005 02:12 PM
GDM93Si
Jan 12, 2005 10:44 PM
azhatch
Jul 16, 2004 05:15 PM
SOUTHCREX
Dec 29, 2003 08:45 PM
