Crank Pulley with an air Compressor
Old Apr 26, 2004 | 02:03 PM
slowls's Avatar
Default Crank Pulley with an air Compressor
Did a search already and found out you could remove the crank pulley with 150 psi but I was wondering about the size of the tank. Will a 15 gallon tank be enough to take the crank pulley off?
Modified by slowls at 4:08 PM 4/26/2004
Old Apr 26, 2004 | 03:08 PM
slowls's Avatar
Someone must know.
HELP
Old Apr 26, 2004 | 03:10 PM
Kal's Avatar
Kal
Default Re: (slowls)
suggest you IM the people who did it.
Old Apr 26, 2004 | 03:40 PM
Padawan's Avatar
Darth ModerVader
Default Re: Crank Pulley with an air Compressor (slowls)
It should be, but keep in mind that the type of gun you use is just as important as the compressor (since you're only using very short bursts, large capacity isn't really critical). Our old 1/2" gun (I don't remember the specs or brand right now) wouldn't budge a crank pulley bolt, but when we switched to a much larger 3/4" Craftsman gun, they're off in a matter of seconds.
Old Apr 26, 2004 | 03:50 PM
slowls's Avatar
Default Re: Crank Pulley with an air Compressor (Padawan)
Thanks Padawan.
You happen to answer my next question about the impact gun.
Old Apr 26, 2004 | 06:20 PM
Echo7847's Avatar
Most impact guns work best @ 90psi. It's all in the gun you get, you dont need anymore than 90 if you have a good gun. I've done it plenty of times with my 1/2".
Old Apr 26, 2004 | 07:15 PM
Mr_CRX's Avatar
Default Re: Crank Pulley with an air Compressor (Echo7847)
I had to crank my brother's gun up to 150 and let it pound on the bolt for a little bit before it came off. It was just a matter of patience for me since we didnt have one of those rambo impact-guns
Old Apr 26, 2004 | 07:20 PM
sikcrx80's Avatar
i just did one and if u cant get it with just the gun u will need to heat it..
i was told red hot but i dont have torches but i have propane and jus theat it for like 5 min and try it... worked for me
Old Apr 26, 2004 | 07:34 PM
kur0ryu's Avatar
Default Re: (sikcrx80)
yup, red-wrenching does wonders to locked nuts and bolts.
Old Apr 26, 2004 | 07:35 PM
fourthgenhatchB17's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">Most impact guns work best @ 90psi. It's all in the gun you get, you dont need anymore than 90 if you have a good gun. I've done it plenty of times with my 1/2".</TD></TR></TABLE>
Very true, and most people set the psi @ the compressor regulator to 90psi. What some people forget is that usually there is a hose between the gun and compressor, so depending on the length of the hose there may not be 90 psi at the other end. I have a 50 ft hose so i bump mine up to like 115-125 psi @ the compressor and i have no problems taking anything off. 1/2 Husky 500 ft lb impact wrench with a 30 gallon 150 psi max compressor.
Old Apr 26, 2004 | 08:45 PM
BuddhaSiR's Avatar
Default Re: Crank Pulley with an air Compressor (fourthgenhatchB17)
ingersol 1/2inch TNT impact gun. made out of titanium with 650 lbs of nut bustin torque. works really good.
Old Apr 27, 2004 | 11:51 AM
GPNY's Avatar
Default Re: Crank Pulley with an air Compressor (BuddhaSiR)
Any 3/4" gun from harbor freight will do the trick for less than 80$.
If you don't use the guns that often, a cheap one will be fine... (why waste money on a professional
My 3/4" harbor freight gun with 90 psi from a small IR portable 2HP compressor has removed several crank pulleys VERY easily.
Modified by Gpelsise at 4:13 PM 4/27/2004
Old Apr 27, 2004 | 12:45 PM
slowls's Avatar
I'm looking to get the same impact gun as BuddhaSiR. Look excellent.
Thanks for all your feed back.
Old Apr 27, 2004 | 02:15 PM
Chiovnidca's Avatar
Default Re: Crank Pulley with an air Compressor (Gpelsise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gpelsise &raquo;</TD></TR><TR><TD CLASS="quote">Any 3/4" gun from harbor freight will do the trick for less than 80$.
$80 for a 3/4 impact? I paid $280 for my IR261 and thought that was a good deal.
Old Apr 27, 2004 | 06:39 PM
GPNY's Avatar
Default Re: Crank Pulley with an air Compressor (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
$80 for a 3/4 impact? I paid $280 for my IR261 and thought that was a good deal.</TD></TR></TABLE>
Yup I have a ton of tools from harborfreight, even a car lift... not great quality, but does the Job fine, and nothing more is NEEDED for DIYer's ... I have have the Impact gun for 2 years now and it's still perfect.
I believe the one I have is:
http://www.harborfreight.com/c...32871
But I thought mine was more powerful... Something like 600ft/lbs max.
Otherwise I saw this one 1/2" drive which should also be fine:
http://www.harborfreight.com/c...=2623
Old Apr 28, 2004 | 10:48 AM
BuddhaSiR's Avatar
http://www.harborfreight.com/c...=2623</TD></TR></TABLE>
two years!! I'm impressed. For something i have to use everyday, i need tools that are gonna last me a while.
Old Apr 28, 2004 | 10:50 AM
BuddhaSiR's Avatar
if you have the crank pulley holding tool, you don't even need an impact gun.
Old Apr 28, 2004 | 10:55 AM
mmuller's Avatar
Mad Scientist
i use some harbor freight tools too, as is my impact wrench. but you always get what you pay for...
get one thats more than 250ft/lb's though
Old Apr 28, 2004 | 11:20 AM
GPNY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">
Like I said, DIYER's do not use their stuff EVERY DAY all day long. For those applications, an Ingersoll Rand Pro series is definitely appropriate.
I use the gun on weekends once in a while, it's still fine. I use another cheap 1/2" gun for smaller bolts, and the 3/4 for heavier duty...
People always talk of spending big money on tools that they really don't need... I have purchased a lot of tools in the past few years, much of them from harborfreight and am still very satisfied.
With regards to what higher quality (Snapon, husky, craftsman, IR, facom...) tools you should get, here's my list:
- Air Compressor
- 12 sockets
- flat wrenches
- Allen/torx impact sockets
- torque wrenches
- electric tools
- floor Jack
- mig/auto darkening mask
Stuff you can go cheap on (I use harbor freight for cheap stuff):
- 2nd/3rd set of flat wrenches (i have 4 sets to leave around 2 is garage, 2 in basement)
- 3/4 inch impact (OR get 1 high power 1/2" instead of 2 cheap ones)
- 1/2 inch impact
- 1/2 impact 6 point sockets - deep and regular (Also have a few sets) - as long as you use the right size (ie nice tight fit) you wont break them easily...
Old Apr 29, 2004 | 01:08 PM
mmoto68's Avatar
Home-made pulley holding tool - 1/4" x 2" bar 18" long. Drill 2 holes to match up with the pulley, skip one hole on the pulley so you have more leverage.
2 foot breaker bar w/impact socket. Don't use an extension.
One foot on breaker bar, hold onto bumper. Pop that sucker off.
Old Apr 29, 2004 | 06:18 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BuddhaSiR &raquo;</TD></TR><TR><TD CLASS="quote">if you have the crank pulley holding tool, you don't even need an impact gun. </TD></TR></TABLE>
you mean this thing:http://www.thetoolwarehouse.net/shop/SP-60100.html
sure cost a hellva lot less then the getting a impact gun + the cost of a compresser. I've done alot of timing belts on hondas and acuras, I have yet used a impact gun. all it takes is a breaker bar, 3 ft cheater bar, and good ol' fashion MUSCLE!!!
Old Apr 29, 2004 | 06:27 PM
sikcrx80's Avatar
remember
heat is ur friend...
Old Apr 29, 2004 | 06:44 PM
hatchedzex's Avatar
definatly use some muscle. chances are if your bolt was like mine the impact gun isnt gonna do ****, i broke the pully bolt in my crank on my old motor. got it out tho so its cool. im with the guy and the 3ft pry bar. mine was 5ft long and my dad stood on it lol come out like a champ just have fun keeping the pully from spinnin on ya, and buy craftsmen tools. i snapped SOOOO MANY 17mm sockets. and broke the mech in a wrench. spend the cash on the impact socket
bradley
13
Jan 9, 2012 02:12 PM
BLKFLSH
Apr 10, 2011 01:54 PM
Powered By Garrett
19
Jul 20, 2008 05:17 PM
neogenesis2004
Mar 24, 2004 02:16 PM
