can any d-series motor be matched with any d-series auto trans?
Old Apr 25, 2004 | 07:29 PM
MoogieBoogie's Avatar
Default can any d-series motor be matched with any d-series auto trans?
If I swap in another D-series engine into my 92 Civic DX auto (sedan), could I keep my auto transmission that is in there now? I'm looking to get the D16Z6 motor or a D15B.
Thanks,
-Brian.
Old Apr 25, 2004 | 08:04 PM
lohatch's Avatar
Default Re: can any d-series motor be matched with any d-series auto trans? (MoogieBoogie)
yes you will be able to keep that tranny. you will have to take the flywheel off the new motor if it was a manual trans car and then put on the plate for the torque converter and then the converter which i assue you have on your current DX motor. you will need a different ECU if you run a vtec motor. idk if they make an auto vtec motor????somebody correct me but i have never seen one?????? help this guy out
Old Apr 25, 2004 | 08:06 PM
lohatch's Avatar
Default Re: can any d-series motor be matched with any d-series auto trans? (lohatch)
also it isnt that hard to do the manual swap and you will love it.
Old Apr 25, 2004 | 08:19 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">yes you will be able to keep that tranny. you will have to take the flywheel off the new motor if it was a manual trans car and then put on the plate for the torque converter and then the converter which i assue you have on your current DX motor. you will need a different ECU if you run a vtec motor. idk if they make an auto vtec motor????somebody correct me but i have never seen one?????? help this guy out </TD></TR></TABLE>
Yes you are totaly right. And yes they do make a auto vtec ECU, I got one of 92-95 EX coupe.
Old Apr 26, 2004 | 12:09 AM
Default Re: can any d-series motor be matched with any d-series auto trans? (ABK)
Thanks again you guys.
Whew, you're gonna get pretty sick of me asking questions before June.
I might attempt the manual swap later though. Lohatch, you keep tempting me!!!
-Brian.
LSteggyguy
Jun 25, 2014 09:34 PM
Benchracer
Oct 10, 2008 11:50 AM
tony n.
10
Nov 9, 2006 03:20 PM
R_type
Dec 19, 2005 09:18 PM
RockLee`
15
Aug 25, 2005 05:23 PM
