EG Fog Lamp Switch
(2)BLACK "ground"- connect them together and run it to you cigerette light plug.
(1)RED "power/illumination"- run it to the same color coded wire on the cigerette plug.
(1) BLUE/YELLOW "remote/switch" - there is a wire the is already in place on your harness. read the instruction:
a) follow the cluster/dash harness where it run to the fuse box.
b)there is a 10 wires "blue" plug that goes down there.
c) look for the blue harness plug and tap the blue/yellow wire to it.
(1) BLACK/YELLOW- this is actually the power wire out of the 5 wires.
"this one if you look behind the fuse box toward the center there is a grey plug with jsut 1 single wire( EG SI only), if you model is an EX then ther is a few wires to that plug...basically tap it into that wires.
after all this is done you hshould have it working like it should when you turn on your parking like and such...
jope this help.
jope this help.
EGKREW
12
Feb 28, 2008 04:14 AM
