where dose this wire plug in to. eg fog lights?????????????????
if those fogs are the same as mine, the black wire on the right is your ground, middle [yellow] is either your positive or negative that goes to into switch and the other wire on the left [next to the yellow one] would be your other positive or negative wire that goes into your switch. but since the yellow wire is 2 wires its kinda different? id say try and ground out the wire on the right, and then plug the other 2 wires into your switch. see what happens. if you blow the fuse then just go pick up a couple more. i got 6 at radio shack for like, 2 bucks. if you mess around with it, youll be able to figure it out =]
Re: where dose this wire plug in to. eg fog lights????????????????? (EGKREW)
Is it a spader connector? Plugs into the accessory slots on your fuse box.
I would plug it into the 2nd one from the right (No. 19 Headlight) fuse. So your fog lights come on with your headlights.
However, if you want your fogs to come on without your headlights, plug it into any of the other four slots.
oh yea, another thing that you could do is if you know about wiring at least a little bit you could strip those wires and rewire it all. its not that hard. if you dont know how, PM me and ill explain it.
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">
Did you try my method?</TD></TR></TABLE>
ya but it didnt work
Re: (EGKREW)
My depo's are the same wire coloring as yours i believe, and i just went outside to look at it for you and the two yellows that come to a spade connector are my power, i just crimped a male spade onto a wire and ran a wire back inside to my fuse box i think to the radio fuse.
