crank hp and wheel hp
Old Apr 25, 2004 | 05:41 PM
User 5426's Avatar
Default crank hp and wheel hp
I have 3 questions.
I want to know the approx. hp % loss to the wheel with hasport mounts.
The setup is
JDM H22a closed deck block.
Standard size Type S pistons
Cometics thin head gasket
Skunk2 Stage 2 cams
Skunk2 Valvesprings
Skunk2 High Comp (standard size) Valves
Skunk2 Retainers
HONDA Valve seals
HONDA Cam seals
HONDA Rod and crank bearings
HONDA Oil pump
HONDA Water pump
HONDA Manual tensioner conversion
HONDA timing belt
HONDA Distributer (new)
ADCCO 11# Flywheel
HONDA Oilpan
Chipped P13 ecu
IAB plate removed, and it has a IL4 70mm TB
Is 210.7 hp and 163 ft pounds possible with this setup?
What is the pros and cons of removing your IAB plate?
Old Apr 25, 2004 | 07:17 PM
User 5426's Avatar
Default Re: crank hp and wheel hp (SeaQuake)
I want to replace my existing motor inside my 92 eh2(hatch) with that one. The seller claims that they got those #'s with a bolt-on setup similar to mine.
Old Apr 26, 2004 | 01:29 PM
doublejz's Avatar
thats very possible since a stock JDM H22A is;
200Hp 161Trq 10.6 Compression (JDM)
I would actually think it would be higher then 210.7/163
Old Apr 26, 2004 | 02:16 PM
JSMC's Avatar
Default Re: crank hp and wheel hp (doublejz)
maybe not at the wheel though!!!, but seem to be good with those mods
Old Apr 26, 2004 | 02:56 PM
Kal's Avatar
Kal
highly doubt it.
Old Apr 26, 2004 | 03:51 PM
Sliced Beard's Avatar
Default Re: crank hp and wheel hp (Kal)
i think it is possible
Old Apr 26, 2004 | 05:58 PM
User 5426's Avatar
Default Re: crank hp and wheel hp (dirtyd463)
lol, I knew that this was one of those questions that there is no definite answer but I have 50-50 which is worst case.
Well, thanks for the replys guys.
N1ConceptsC
11
May 17, 2010 10:44 AM
TylerB
Mar 19, 2009 08:16 PM
User 5426
May 1, 2004 09:58 AM
User 5426
Apr 29, 2004 12:17 AM
