How many washers for DIY rear camber kit
Old Apr 25, 2004 | 11:51 AM
FerioVtec94's Avatar
Default How many washers for DIY rear camber kit
My car is lowered about 2 1/4 inches....how many washers should i use in the rear?
Old Apr 25, 2004 | 12:25 PM
-Gambit-'s Avatar
Default Re: How many washers for DIY rear camber kit (FerioVtec94)
depends on how thick the washers are, its a trail and error thing for the most part.
Old Apr 25, 2004 | 01:31 PM
dimotorsports's Avatar
Default Re: How many washers for DIY rear camber kit (Geeky_Gambit33)
I used 3 washers to shim mine. I am not sure what the actuall thickness was, but prolly somewhere around 1/16" ea. Basically, I shimmed them until I had the tire sidewall almost up the the rubber seal lining the rear fender. I also replaced the bolts holding the tiebar to the car. I used longer and harder ones to replace them. If you decide to do the same, visit NAPA or a specialized fastner shop and buy Grade 8 or better. Good luck.
Old Apr 25, 2004 | 01:49 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: How many washers for DIY rear camber kit (dimotorsports)
i used 4 washers for my 3" drop.
Old Apr 25, 2004 | 01:50 PM
thanks guys, good info
funkdocivic
15
Jul 27, 2007 12:23 PM
acercord
Nov 23, 2005 07:55 PM
Kool305
Suspension & Brakes
Mar 13, 2005 07:07 PM
kevinoneill
May 12, 2004 05:39 PM
sleepyEK
Nov 25, 2003 09:27 AM
