How many washers for DIY rear camber kit
Re: How many washers for DIY rear camber kit (Geeky_Gambit33)
I used 3 washers to shim mine. I am not sure what the actuall thickness was, but prolly somewhere around 1/16" ea. Basically, I shimmed them until I had the tire sidewall almost up the the rubber seal lining the rear fender. I also replaced the bolts holding the tiebar to the car. I used longer and harder ones to replace them. If you decide to do the same, visit NAPA or a specialized fastner shop and buy Grade 8 or better. Good luck.
funkdocivic
15
07-27-2007 12:23 PM
kevinoneill
05-12-2004 05:39 PM
