switched to OBD-1 from OBD-2, Question?
Old Apr 25, 2004 | 10:16 AM
Enrikez's Avatar
Default switched to OBD-1 from OBD-2, Question?
I have a 2000 civic si that i switched back to OBD-1 using a harness, would i also need to change my primary O2 sensor to an OBD-1 O2 sensor. Also same with the MAP sensor. should i have to change them both. if i was to change them what kind of Honda should i get them from. I was thinking from like a 92-95 honda civic EX or like an Integra GSR(same years).
whatcha think.
Old Apr 25, 2004 | 04:36 PM
Enrikez's Avatar
Default Re: switched to OBD-1 from OBD-2, Question? (1meanB18c5civic)
anyone.
Old Apr 25, 2004 | 08:41 PM
IDriveHonda's Avatar
I don't think you have to change anything. On the O2 part numbers it says 92-00 and I believe that the maps are the same too, just in different locations.
Old Apr 27, 2004 | 03:50 PM
hialeahzbg's Avatar
you do not have to change anything. i have the same setup in my '00 hatch. just plug and play!!!!!!!!!11
Old Apr 27, 2004 | 04:18 PM
ekb18cCivic's Avatar
Default Re: switched to OBD-1 from OBD-2, Question? (IDriveHonda)
you dont have to changeanything.. the only differnec between the obd1 and obd2 is the plugs the snesors are the same.. since you only used the jumper harness you are good to go
l1l_r1cky
Feb 28, 2012 01:27 AM
Ruben19
Mar 29, 2006 10:11 AM
elmalouno
Jul 18, 2004 08:55 PM
BI8B
Nov 21, 2003 02:33 PM
5 Skware
Jul 30, 2003 04:32 AM
