Dumb TPS Question
Old Apr 24, 2004 | 10:17 PM
FredoSP's Avatar
Default Dumb TPS Question
Hey Guys,
I know I need to use a multimeter and that I want to isolate the middle wire and check the voltage, but I don't know how. Obviously when the connector is plugged into the harness (on the sensor) you cannot get a wire in there so u can't get a reading that way.
I don't have a clue on how to get a reading. People say "probe" the wire, but you cannot take your multimeter and get a reading through the wires' insulation.
I have to be over looking something really dumb. Anyone give me a little help.
so the + end of the probe will be on the middle wire and the other end - will be on the ground off the TPS?
P.S. This is for an STR throttle body, I'm trying to calibrate the sensors position - I already the the volt ranges at WOT and Idle.
Old Apr 24, 2004 | 11:12 PM
Xsi's Avatar
Xsi
I just stripped back some of the insulation.
http://www.integra.orcon.net.nz/tps
Old Apr 25, 2004 | 01:59 AM
Trac226's Avatar
Default Re: (Xsi)
A shortcut I use is to use a sharp probe lead that'll poke right through the wire's insulation. Quick and easy and no real damage.
Old Apr 25, 2004 | 03:39 AM
Chiovnidca's Avatar
Default Re: (Trac226)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Trac226 &raquo;</TD></TR><TR><TD CLASS="quote">A shortcut I use is to use a sharp probe lead that'll poke right through the wire's insulation. Quick and easy and no real damage.</TD></TR></TABLE>
Or you can backprobe the connector pin itself.
Old Apr 25, 2004 | 06:21 AM
IN VTEC's Avatar
Default Re: Dumb TPS Question (FredoSP)
I do if from the back of the ECU harness.
I can't remember the pin numbers right now, but it's in the manual on the wiring schematics. red/blk and I tink ylw/grn
Old Apr 25, 2004 | 07:43 PM
Big Teggie's Avatar
Default Re: Dumb TPS Question (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I do if from the back of the ECU harness.
I can't remember the pin numbers right now, but it's in the manual on the wiring schematics. red/blk and I tink ylw/grn</TD></TR></TABLE>
Thats how I do it. I actually spliced a wire lead into the TPS wire and use that to connect to the multimeter.
Old Apr 26, 2004 | 10:03 AM
tgreaves's Avatar
Old Apr 26, 2004 | 12:51 PM
moto27cm's Avatar
Its d11(+) and d22(-). Wire colors vary between models.
Old Apr 26, 2004 | 01:22 PM
doublejz's Avatar
Default Re: (moto27cm)
if you take off the throttle body with the tps attached and have a multimeter that reads resistance, you can just put a both probes on both pins and it'll give you a reading.
Old Apr 26, 2004 | 02:26 PM
Chiovnidca's Avatar
Default Re: (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">if you take off the throttle body with the tps attached and have a multimeter that reads resistance, you can just put a both probes on both pins and it'll give you a reading.</TD></TR></TABLE>
What should the readings be though?
Old Apr 26, 2004 | 04:01 PM
Sliced Beard's Avatar
Default Re: (Chiovnidca)
i just take a multi meter that has sharp test probes and just kinda "stab" the wire's shield and get my reading that way. very simple to do
Old Apr 26, 2004 | 09:36 PM
FredoSP's Avatar
Default Re: (dirtyd463)
thanks guys, i got everything done
giddyup21
Mar 18, 2012 06:49 PM
dohc_profile
Nov 27, 2006 07:26 AM
FredoSP
Apr 25, 2004 04:47 PM
drjondurst
21
Apr 9, 2003 08:37 PM
