How NOT to break axles?
Old Oct 31, 2001 | 09:35 AM
HybridMT's Avatar
GSRcaucAZN78
Default How NOT to break axles?
Is there anything I can do to not break axles so easily? I try to be careful, but they're still breakin on me. I broke one launching with sliccs at 6000 two weeks ago. Last week I broke one doing a burnout on street tires at 4000. I keep breaking the drivers side axles.
Old Oct 31, 2001 | 09:41 AM
Big Phat R's Avatar
Default Re: How NOT to break axles? (GSRcaucAZN78)
Get forged axles and maybe a less aggressive clutch.
Old Oct 31, 2001 | 10:17 AM
JimmieD's Avatar
get teh z-10 radius arms to cut down on wheel hop(which causes axles to break) and if need be check out http://www.driveshaftshop.com to get their stage two axles.
Old Oct 31, 2001 | 10:47 AM
TRuST's Avatar
What kind of power are you putting down ?
Old Oct 31, 2001 | 12:17 PM
HybridMT's Avatar
GSRcaucAZN78
Default Re: How NOT to break axles? (TRuST)
Just a JRSC @ 6 psi with race gas & stock timing.
Old Oct 31, 2001 | 12:47 PM
chri5's Avatar
if you dont spin your slicks at all you will break axles. The spinning is what protects the axles from all the twisting force on the launch. If you want the best launches you are going to break stock axles eventually. Thats how it goes.
Old Oct 31, 2001 | 06:59 PM
TRuST's Avatar
Default Re: How NOT to break axles? (slipknot1)
You won't be able to move and when you try to move it will just make a fast thud noise.
Old Oct 31, 2001 | 08:09 PM
OneThirtyEight's Avatar
whenever i shift at high RPM, its like a THUD(feels like a sledge hammer on my engine) squeel. Its my tires i know, how bad is this for the car? or sometimes it will hop on shifts real high RPM? How bad is that?
[Modified by 97blackteg, 12:12 AM 11/1/2001]
Old Nov 1, 2001 | 04:39 AM
TRuST's Avatar
Default Re: How NOT to break axles? (97blackteg)
It can also be possible that you motor mounts are going bad and the motor is just slamming against the motor mounts.
Are you talking about the wheel hop you get on a launch or just shifting. If it's on your launch then yes it is possible you could break an axle.
Here's a picture of the Z10 kit installed.
[Modified by TRuST, 8:41 AM 11/1/2001]
Old Nov 1, 2001 | 07:37 AM
BeanRacer's Avatar
New User
How much is that kit?
Old Nov 1, 2001 | 08:09 AM
H23 Power's Avatar
Default Re: How NOT to break axles? (BeanRacer)
yeah, how much is that kit? looks pretty easy to install
nevermind, just found it, $390...thats A LOT of money for what is there. oh well
[Modified by 01GSR, 11:12 AM 11/1/2001]
Old Nov 1, 2001 | 09:05 AM
junglistgsr's Avatar
Default Re: How NOT to break axles? (01GSR)
they are doing a groupbuy in the best buys forum for $330
OG undercover
Dec 16, 2006 06:22 AM
ek9800
May 25, 2005 12:30 PM
hybrid901
May 23, 2002 06:28 AM
