Switches?
Old Nov 1, 2001 | 05:08 AM
kacerdias's Avatar
New User
Default Switches?
Got a question for you guys out there. I just installed a set of PIAA 912's on my GSR and ran the switch that came with them to the center console where the parking brake is. There are 4 little plastic tabs that pop out and look like they were designed to have switches mounted in them. Do you know of any company that makes modular switches that are designed to fit in those slots? I thought about drilling the one I have and custom mounting it, but the PIAA switch has a custom funky little circuit board in the switch casing that even when shaved won't fit in the OEM switch-hole cover.
Old Nov 1, 2001 | 05:25 AM
TurBoTeG's Avatar
Default Re: Switches? (kacerdias)
I went to Home Depot and got a nice switch that just bearly fit into those plastic tabs. The reason for it is when you pop them out look on the back side...the plastic square is in a wierd shape and its a big pain in the *** but ive successfully did it very nicely...as for the piaa switch...i im sure that it can be pulled off but its probably not worth it...what i did..is snuck the switch to the drivers side..at the bottom of the counsel where the carpet and the counsel meet where nobody has access to it but the driver...
Old Nov 1, 2001 | 07:52 AM
Phat Corolla's Avatar
New User
Default Re: Switches? (TurBoTeG)
I have some Hella Optiplex Fogs, and it came with a really cool LED type button that changed color when on and off. It didn't even close to fit in the spaces in the center console, so I took it and cut it down to the correct shape and then did some plastic-working to mold it into the correct size. It turned out really good. If i had a digital camera, I'd post a pic, but I don't, so sorry.
Old Nov 1, 2001 | 08:03 AM
H23 Power's Avatar
Default Re: Switches? (Phat GS-R)
home depot switches
if you have a black console, i'd be willing to trade a couple of these for your stock inserts....something to think about...I took of the nitrous kit so i don't need all of them anymore
[Modified by 01GSR, 11:05 AM 11/1/2001]
Old Nov 1, 2001 | 08:36 AM
BlazinITR's Avatar
New User
Here's a image of mines!
Old Nov 1, 2001 | 08:38 AM
New User
Default Re: Switches? (Blazin ITR)
dude, I like your interior, from what I can see of it.
Old Nov 1, 2001 | 08:43 AM
kacerdias's Avatar
New User
Default Re: Switches? (01GSR)
Yup, those are the panels I was talking about. I'm looking for something a little smaller, but I think that might work. The problem is the PIAA's have a circuit board along with them with a dual-color LED. Not sure if that would make a difference and I certainly don't want to end up killing these lights. The switches do look pretty good though.
Old Nov 1, 2001 | 09:27 AM
TurBoTeG's Avatar
Sweet i wasnt the only one who got the SAME EXACT switches from home depot
Axatax
May 10, 2012 08:19 AM
acura_el2000
43
Apr 10, 2009 11:57 AM
Josh_With_The_S2K
Honda S2000
Jan 31, 2008 08:36 PM
Jos3ph
Jun 5, 2007 03:19 PM
GuCCi_GSR
Aug 7, 2006 02:45 PM
