VAFC-II
Old Apr 23, 2004 | 08:49 PM
brian2903's Avatar
Default VAFC-II
After I installed the VAFC-II. Sometimes the check engine light turn on, but after I restart the car, its off again. However, the light is on no matter how many times I restart it.
When I check the code in Honda dealer, they said the code is about the Vtec.
Anyone know what's wrong???
Old Apr 24, 2004 | 08:58 PM
brian2903's Avatar
Default Re: VAFC-II (brian2903)
bump
Old Apr 24, 2004 | 09:29 PM
stRodda's Avatar
what about vtec?? what code are you getting? get a paperclip and check it, you dont need to waste your time with the dealer.
Old Apr 25, 2004 | 12:07 PM
fw190bvi's Avatar
Default Re: VAFC-II (stRodda)
is it because the engagement point setting is all f'ed up???....j00 need to pull the exact code yo
Old Apr 25, 2004 | 06:22 PM
brian2903's Avatar
code 21
should be about vtec. when check engine light is on, the fuel cut at 6000rpm, and no vtec enage.
Thanks.
Old Apr 29, 2004 | 12:21 AM
stRodda's Avatar
its your vtec solenoid... fix it or get a new one.
Old Apr 29, 2004 | 09:18 AM
brian2903's Avatar
What do u mean by " vtec solenoid" ?
how to fix it?
Old Apr 29, 2004 | 10:28 AM
Daniel M.'s Avatar
I think the check light comes on because the Vafc tircks your ECU and it thinks there is an error.
Try disconnecting the Vafc and if the check engin light comes on again it means you have to change you Vtec solenoid.
Old Apr 29, 2004 | 10:45 AM
stRodda's Avatar
Default Re: VAFC-II (Daniel M.)
thats true too, the vafc could just be causing a glitch. but if it is your solenoid, check it out.
heres what it looks like
Old Apr 29, 2004 | 12:57 PM
Daniel M.'s Avatar
Or it can also be that you diden't connect the Vafc correctly!
Old Apr 29, 2004 | 03:35 PM
Va Iceberg's Avatar
Default Re: VAFC-II (fw190bvi)
Yo how much are you selling
Old Apr 29, 2004 | 07:20 PM
brian2903's Avatar
I drove my car today,t eh CEL off. However, when I was driving back to home, I stopped in front of the stop sign. It comes on again.......
HELP ~~~~~~~~~~~
Old Apr 29, 2004 | 07:22 PM
brian2903's Avatar
BTW, if I connect the vafc wrong. The CEL won't off sometimes, right?
Old May 2, 2004 | 12:10 PM
brian2903's Avatar
Please help
wlanford
Feb 18, 2014 08:16 AM
TurkeySlayer
Dec 19, 2011 10:37 AM
Quade
Jun 15, 2004 10:27 AM
inzaneN1
Dec 3, 2003 01:34 AM
boosted spoon
Jul 23, 2002 12:08 PM
