Excessive Smoke...
Old Apr 23, 2004 | 07:56 PM
ExVtec's Avatar
Default Excessive Smoke...
Ok, I am confused. I just got a 2.5" exhuast, straight through for now. Waiting on a muffler, resonator and cat. I am boosted maybe a month or so with a custom setup using a mitsubishi 14b. Intercoolered on the hack (untuned) for now. 5-7 psi. I just noticed the white smoke escaping from my tailpipe. When it idles it streams out pretty even, when I am WOT, it barely smokes, then when I let off the gas or shift it billows out...Is this a side affect of no cat? Or is there a more serious problem. Cracked block/headgasket. The car runs great all the way to redline. I am going to change my oil this weekend to see if there is any antifreeze in my oil. Any help would be greatly apprecaited.
Thanks all....
Old Apr 23, 2004 | 10:36 PM
TIRENECK's Avatar
Default Re: Excessive Smoke... (ExVtec)
could be turbo going bad but mainly it would be the headgasket.
Old Apr 24, 2004 | 12:13 AM
xplanetearth420x's Avatar
Default Re: Excessive Smoke... (TIRENECK)
ya check you oil see if it dirty and see if theres any antifreeze in it
Old Apr 24, 2004 | 06:33 AM
ExVtec's Avatar
Well the turbo isn't watercooled. If the seals in the turbo are bad, would it be light smoke? I am changing my oil today, to see if there is any antifreeze in it....
Old Apr 24, 2004 | 09:42 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec &raquo;</TD></TR><TR><TD CLASS="quote">Well the turbo isn't watercooled. If the seals in the turbo are bad, would it be light smoke? I am changing my oil today, to see if there is any antifreeze in it....</TD></TR></TABLE>
I'm also going to go ahead and say it's the seals in the turbo.
You can pick those turbos up for cheap & low miles at dsmtrader.com
I'd go ahead and just buy a new one
Old Apr 24, 2004 | 11:48 AM
ExVtec's Avatar
Default Re: Excessive Smoke... (Usdmdc2)
hmm..what makes you all think its the turbo seals?
smokes some while i am wot, not much normal cruising no boost...
when i stop @ and it sits idling for a 30 secs or more...it really billows the smoke....
Old Apr 24, 2004 | 07:09 PM
AzG35's Avatar
My friends smoked bad at idle too. The turbo seal was bad, and caused it to smoke when sitting only, but it was blue, not white.
superslow-oto
Jun 11, 2008 10:57 AM
cooltron
Mar 28, 2008 01:54 AM
jdmcreations777
May 30, 2007 11:41 AM
LxSedan
May 15, 2005 07:31 PM
ExVtec
Apr 26, 2004 09:24 AM
