Sluggish....then power
Old Apr 23, 2004 | 06:20 PM
94civicNewbie's Avatar
Default Sluggish....then power
I was just looking for some opinions on what the problem may be. I have a 94 civic ex and a few weeks ago I blew the main relay plus the distributor was bad. So. I purchased a used distributor, looks good and had low miles on it, and got a new relay plus put in some new plugs. They are NGK 1095s. They are one range colder then stock. OK now for the problem. I put the car in first and hit the gas and the car slugs. It feels bogged down till the rpms rise up then it takes off. Then when I shift to secound it does the same thing. Real sluggish then back to normal. Should I go back to stock plugs? Could I be misfiring? Any help is very much appriciated.
Old Apr 23, 2004 | 06:47 PM
Luserkid's Avatar
Default Re: Sluggish....then power (94civicNewbie)
Could be a vaccum leak. Try stock plugs and see if that makes a difference, but im thinking vaccum leak.
Old Apr 23, 2004 | 06:58 PM
Default Re: Sluggish....then power (Luserkid)
Where could the vacuum leak be? Throttle body? Where else? Thanks
Old Apr 23, 2004 | 07:03 PM
Luserkid's Avatar
Look over the IM and see if theres any hose's lose or coming lose. Atleast thats my guess because thats what happened to me.
Could also be your spark plugs, what are they gapped to?
Old Apr 23, 2004 | 07:14 PM
I gapped them today to .035.
Old Apr 23, 2004 | 07:23 PM
Luserkid's Avatar
What motor? and i would try .040-.044 (not saying thats right or wrong but thats what i use and i dont have a problem).
Old Apr 23, 2004 | 07:25 PM
Its a D16Z6. Its my Honda learning engine. Gotta start somewhere right? Newbie question but, what does a bigger gap do vs a smaller gap? Thanks
Old Apr 23, 2004 | 07:26 PM
Jaydeep's Avatar
My car has same problem. I think my car might have vacuum leak. But I don't know how to check that. Could you guys help me out.
thanks
Old Apr 23, 2004 | 07:30 PM
SOHCwarrior's Avatar
Default Re: Sluggish....then power (Jaydeep)
Did you get the timing after you put on the new dist.? it sounds like it could be timing especailly if you changed the dizzy
Old Apr 23, 2004 | 07:44 PM
Default Re: Sluggish....then power (SOHCwarrior)
So just adjust the timing belt normaly? And check for vacuum leaks. Anything else I could try? Thanks for all the help.
Old Apr 23, 2004 | 07:46 PM
The King's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94civicNewbie &raquo;</TD></TR><TR><TD CLASS="quote">So just adjust the timing belt normaly? And check for vacuum leaks. Anything else I could try? Thanks for all the help.</TD></TR></TABLE>
adjust the timing you'll be fine from there
Old Apr 23, 2004 | 08:49 PM
hadehatch's Avatar
Default Re: Sluggish....then power (ReDRoCkEt)
id also say its the timing.. a few friends have had the same problem.. maybe when your distributor was bad it caused the timing belt to jump a tooth... check that out.. hope that helps..
Old Apr 23, 2004 | 08:59 PM
Br1anPham's Avatar
Default Re: Sluggish....then power (hadehatch)
im thinking the dizzy also since you did change it. Timing light is going to be your friend here
Old Apr 23, 2004 | 09:01 PM
bad93ex's Avatar
I would check the timing.
Old Apr 23, 2004 | 10:34 PM
DAguyLS's Avatar
you can spray starting fluid around your hoses to check for a vac. leak. Don't go crazy on the spray and it'll be safe. If the car idle never moves during this, then it's a good sign of no vac leaks.
Old Apr 25, 2004 | 10:05 AM
Thanks for the all help yall. Turns out it was the timing. I had the Dist. offset to much. Thanks again.
Old Apr 27, 2004 | 11:19 PM
The King's Avatar
told ya so
jchung
26
Mar 16, 2007 11:24 PM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
nekoabandoned
Dec 27, 2005 09:57 PM
Touge Tuning
Jun 27, 2005 06:42 AM
krazn
12
Nov 22, 2002 08:36 PM
