did a compression test today
Old Apr 23, 2004 | 12:41 PM
danny98r's Avatar
Default did a compression test today
1. 215
2. 220
3. 220
4. 230
how do these numbers match up to other stock type r's
MAD ITR 55's Avatar
Default Re: did a compression test today (danny98r)
Yes your #'s are fine
Old Apr 23, 2004 | 12:58 PM
typer_801's Avatar
Pretty Normal - about the same as mine...
Old Apr 23, 2004 | 01:58 PM
danny98r's Avatar
Default Re: did a compression test today (typer_801)
i did this test when the egine was hot. am i supposed to wait till it cools down? will i see different numbers? my engine only has 18,000 miles so im really expecting these numbers to line up evenly
Old Apr 23, 2004 | 03:43 PM
junbb1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danny98r &raquo;</TD></TR><TR><TD CLASS="quote">i did this test when the egine was hot. am i supposed to wait till it cools down? will i see different numbers? my engine only has 18,000 miles so im really expecting these numbers to line up evenly</TD></TR></TABLE>
no you do a compression test when the engine is at operating temp and the throttle wide open.
if you do it cold the numbers will be lower
Old Apr 23, 2004 | 03:50 PM
nightrider's Avatar
you're being a little ****. you have fine numbers regardless of how many miles you have. it's more important to have consistent numbers.
edit: consistent = no more than 20 between cylinders.
jdmcivic2fast
Oct 2, 2011 08:19 PM
EG2Driver
Jul 12, 2006 04:01 PM
John.
Jun 12, 2006 08:45 AM
snowblind7x
Apr 13, 2005 08:12 PM
JunIntegra
Jul 1, 2003 01:40 PM
