timing belt install b16 question
Old Apr 23, 2004 | 08:26 AM
spaceman's Avatar
Default timing belt install b16 question
so i put the belt on then i tighten it down with the tensioner,then do i turn the crank counterclockwise to tighten it more or what do i do?
Old Apr 23, 2004 | 08:44 AM
spaceman's Avatar
Default Re: timing belt install b16 question (spaceman)
cmon doods this isnt complicated,is it?hehe,jus let me know so i can finish work,please
Old Apr 23, 2004 | 10:13 AM
kur0ryu's Avatar
put the belt on, while everything's on TDC, tighten the tensioner, turn the crank so the cams advance like 3 teeth, then loosen the tensioner so it picks up the slack, then retighten. Then turn the crank to TDC to verify that the cams are lined up too. Hope that helps!
Old Apr 23, 2004 | 10:48 AM
spaceman's Avatar
Default Re: timing belt install b16 question (kur0ryu)
thanks bro,do i turn the crank counterclockwise?
Old Apr 23, 2004 | 11:24 AM
nolimits's Avatar
Yep...it'll make sense when you see how much slack it picks up
Old Apr 23, 2004 | 11:26 AM
spaceman's Avatar
Default Re: timing belt install b16 question (nolimits)
cool,right on dood.jus wanna make sure on what to do..i got a kinda off topic question,when i take off the head to change the head gasket will there be any other seals,orings,etc.that i should change?
Old Apr 23, 2004 | 11:39 AM
nolimits's Avatar
Just the head gasket should be fine
Old Apr 23, 2004 | 11:41 AM
spaceman's Avatar
ok,i got another question are those self locking exhaust manifold bolts re-usable?
Old Apr 23, 2004 | 11:52 AM
kur0ryu's Avatar
yeah, just be very careful when removing and torquing, they strip easy.
Old Apr 23, 2004 | 11:54 AM
spaceman's Avatar
thanks for the info,ill be back with more questions as i continue working..
Old Apr 23, 2004 | 11:55 AM
kur0ryu's Avatar
Oh yeah, and when you change the headgasket, you might want to change all the top end seals, if you're not planning on removing the head again and this is replacing the headgasket as a regular matienance, you might want to just buy a top-end gasket kit. it's cheaper to buy it that way, it takes care of your valve cover seals, head gasket, intake, exhaust, cam seals, etc.
Old Apr 23, 2004 | 12:14 PM
nolimits's Avatar
Good advise. If you don't go that route, and you remove the exaust manifold, you'll need to replace that gasket. Same goes for the intake manifold, although it's not necessary to remove it. Rubber gaskets can often be reused if they are still in good condition...any paper/metal/etc gaskets need to be replaced each time (although sometimes they can be reused successfully, it's not worth the risk of extra labor and finding leaks for the cost of a new gasket)
No_jdm_fanboys
Jun 1, 2014 08:59 PM
potential
Oct 7, 2006 07:52 PM
Ls91sI
Aug 4, 2005 04:13 AM
sk8rmike
Dec 21, 2004 07:11 PM
