timing belt wont tension
Old 10-07-2006, 02:57 PM
potential's Avatar
Default timing belt wont tension
ok so i put a d16y7 head onto a b7 block but now the timing belt wont tension when i want it to. i loosend the tensioner bolt and turned the crnkshaft about three teeth counter clockwise untill the front of the belt was tensioned(closest to the radiator) but now the back side wont tension. when i turn the crank clockwise to tension th back side the the belt jumps off the crank pully. it doesnt seem to tighten, i measured everything on the old head and the new head and there is no reason y it shouldnt work. any help please.
Old 10-07-2006, 03:26 PM
F20Cteg's Avatar
Default Re: timing belt wont tension (potential)
You are doing it right by turning it three teeth in the CCW direction, but stop turning the crank in the CW direction. After you turn the three teeth and then tighten the tensioner and contuinue turning the crank in the CCW direction. Do it about 4-6 complete rotations and then check to see if everything is still lined up.
The engine doesn't rotate CW and the timing belt can (will in your case) jump a tooth.
Old 10-07-2006, 07:52 PM
nighttrain33's Avatar
Stupid question, but do you have the right belt?
-Shane
Mishako129
09-04-2012 10:14 PM
aznflipboi08
12-27-2009 11:24 PM
teler86
05-18-2006 06:29 PM
omgwtfbbqcrx
02-16-2006 09:38 PM
d16rice
04-20-2005 11:48 AM
Quick Reply: timing belt wont tension
