01 civic ex leaning out on boost?????
Old Apr 23, 2004 | 03:53 AM
js4uhaterz's Avatar
Default 01 civic ex leaning out on boost?????
does anyone know what injectors will fit besides stock.....
car leans out about 5500 rpm and need advice........
thank you
Old Apr 23, 2004 | 04:34 AM
b18c1civic95's Avatar
Default Re: 01 civic ex leaning out on boost????? (js4uhaterz)
grab a set of eclipse ones and get a vafc or safc for that matter....
Old Apr 23, 2004 | 06:14 AM
what the...'s Avatar
Hey! holy ****, somebody that ACTUALLY NEEDS a vafc! wow, it's an honor to meet you. If I had a nickel for every 'my vafc doesn't work' thread I've seen in the past two weeks....
well, I wouldn't be able to buy jack **** but I'd definitely have a fistful of nickels.
Homeboy is right, you may not even need to buy injectors (depends on how lean your getting). But you can get vafc, safc, for about 175 used and in great condition. Get it all dyno tuned, and if you're still a little lean then start looking at some larger injectors. good luck with your setup
Old Apr 23, 2004 | 06:46 AM
js4uhaterz's Avatar
Default Re: 01 civic ex leaning out on boost????? (what the...)
vafc, safc.....been there, done that......injectors are still too small......looking for injectors that will fit in 01 ex fuel rail....remember that year civic does not have reg mounted on rail......internal
Old Apr 23, 2004 | 06:47 AM
js4uhaterz's Avatar
thank you
Old Apr 23, 2004 | 07:15 AM
Kal's Avatar
Kal
have you checked into rc fuel injectors yet?
Old Apr 23, 2004 | 07:19 AM
js4uhaterz's Avatar
Default Re: 01 civic ex leaning out on boost????? (Kal)
yeah injectors are totally different.....dont fit in rail........have to be custom....
Old Apr 23, 2004 | 07:32 AM
Kal's Avatar
Kal
post into the forced induction forum, i'm sure another person like you has a similar problem with a solution maybe.
Old Apr 23, 2004 | 01:46 PM
delacampos's Avatar
will rsx injectors work for you? are they larger than civic injectors?
b20turbojason
Aug 7, 2004 04:58 PM
Nextelbuddy
Dec 5, 2003 05:35 PM
quik2kSi
Jul 17, 2003 07:09 PM
turbod16y7vtec
Oct 30, 2002 07:11 AM
1.8T_EG
Sep 16, 2002 12:22 PM
