Help CEL problem
Old Apr 22, 2004 | 09:21 PM
hair_rice's Avatar
Default Help CEL problem
alright i was driving tonight and i hit a small bump in the road from construction and after a few seconds my CEL went on...so i did what anyone else would do and pull the code and it was 61...i looked it up and it had somehtin to do with my primary o2 sensor or somethin...i have a 99 civic ex with a JDM b16 sir2 motor...any one know what could be the problem, im kinda of lost here and not sure what i should do or look for...all help is greatly appreciated
thanks in advance!!!
this what it says exactly:
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
Modified by hair_rice at 6:35 AM 4/23/2004
Old Apr 23, 2004 | 05:30 AM
JimBlake's Avatar
Default Re: Help CEL problem (hair_rice)
You could check the wiring to the sensor. Is your exhaust loose at all? Maybe the bump pulled too much on the wires? Rule out the easy stuff first like maybe it came unplugged or broke a wire. Corroded connections?
Then reset your ECU & see if it comes back. If it doesn't, then it could be bogus. If the sensor was cheaper, you could just get a new one to try, but I usually look for other problems first.
Old Apr 23, 2004 | 11:19 AM
hair_rice's Avatar
Default Re: Help CEL problem (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">You could check the wiring to the sensor. Is your exhaust loose at all? Maybe the bump pulled too much on the wires? Rule out the easy stuff first like maybe it came unplugged or broke a wire. Corroded connections?
actually checkin it right now...ill let u guys know thanks
lmike6453
Oct 29, 2009 06:02 PM
SC61HB
Oct 11, 2008 07:55 AM
florida
Nov 19, 2007 05:00 PM
SOHCex20
15
Oct 2, 2005 12:36 AM
