Compression vs Leakdown
Old Apr 22, 2004 | 07:39 PM
Mr.Integra's Avatar
Default Compression vs Leakdown
Need a quick answer..
Compression measures cranking pressure. Leakdown measures if you have any leaks in your chamber.
Now here's my question. If my compression numbers are okay, does that mean that my leakdown numbers will be okay too? If not, then why not?
The reason I ask is because I was told that if my compression numbers are fine, then i woudnl't have to do a leakdown test will be okay too.
TIA
Old Apr 22, 2004 | 07:45 PM
Kendall's Avatar
If your compression numbers are okay, then your leakdown test should be good as well. If a compression test comes out good, then I wouldn't worry.
Old Apr 22, 2004 | 07:52 PM
RYAN_SJ's Avatar
Default Re: Compression vs Leakdown (Mr.Integra)
No, do both. The leakdown is testing the combustion chamber sealed, the compression is not.
Old Apr 22, 2004 | 07:55 PM
StorminMatt's Avatar
Default Re: Compression vs Leakdown (RYAN_SJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RYAN_SJ &raquo;</TD></TR><TR><TD CLASS="quote">No, do both. The leakdown is testing the combustion chamber sealed, the compression is not.</TD></TR></TABLE>
Actually, the combustion chamber is 'sealed' in both tests. And a good compression test WILL mean a good leakdown test. The main purpose of a leakdown test is to find the source of leakage. But it won't reveal a cylinder sealing problem that a compression test 'can't'.
self_made
Jun 19, 2005 12:36 PM
snowblind7x
Apr 13, 2005 08:12 PM
Mr.Integra
Apr 22, 2004 07:56 PM
